Help
Old Aug 25, 2016 | 07:01 AM
hdwd2000's Avatar
hdwd2000
Default Help
Lost the light on my radio last night, any ideas? Or is it a dealer fix only.
Old Aug 25, 2016 | 07:10 AM
decencyxdefied's Avatar
decencyxdefied
If u wanna keep the hk radio you can send it to iron cross and let them fix it, buy a used hk radio or buy an aftermarket one
Old Aug 25, 2016 | 07:25 AM
hdwd2000's Avatar
hdwd2000
so there is no fix I can do
Old Aug 25, 2016 | 08:31 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Sucks you are having this issue. Here are some things you can try.
Check display dimness, make sure you did not turn it down all the way.
Can try a ROM Default Reset:
1. With Radio ON press soft keys 1, 3, and OK at the same time and then release.
2. Press UP arrow two times.
3. Press soft key 2 once.
4. Turn ignition off for 30 seconds
5. Turn on ignition.
Display should now work.
or try below and see if there are other issues.
https://www.hdforums.com/forum/touri...ay-repair.html
sdharon
May 6, 2017 10:30 AM
Steel Wheels
2014-2024 Touring Models
Aug 4, 2016 11:21 AM
Bob DiFiore
Oct 20, 2015 09:51 PM
swomack
May 24, 2011 11:13 AM
harleykris
Apr 30, 2008 05:46 PM
