Rear brake problem solved
Old Aug 27, 2016 | 09:11 PM
hemi1300's Avatar
hemi1300
Default Rear brake problem solved
Posted a few weeks ago about the rear brakes making a howling/screeching type noise on my 14 sgs with 10k miles. Finally got time to take a look at it today. Pulled the rear caliper, bc the noise was definitely coming from the rear. Cleaned the pads with brake cleaner and applied disk quiet to the back of the pads. So far, after a short ride, brakes are quiet as a mouse
Old Aug 27, 2016 | 09:32 PM
CndUltra95's Avatar
CndUltra95
You sprayed brake cleaner on your break pads?
A flat file would have sufficed and the cleaner and a clean rag to the rotor(s)
I would watch how your pads are holding up...then again maybe I missed something on what you actually experienced.
Rob
Old Aug 28, 2016 | 07:57 AM
hemi1300's Avatar
hemi1300
Rob
Now I'm confused. What's wrong with spraying brake cleaner on brake pads to clean all the filthy brake dust off them? Isn't that what brake cleaner is intended for?
Old Aug 28, 2016 | 08:54 AM
bagman1's Avatar
bagman1
Nothing wrong with using that. Yes that is what its designed for. Ive seen it used to clean 16" brake shoes that had a leaky wheel seal, shoes went on to last 50-60K miles.
harleyjth
2014-2024 Touring Models
May 13, 2014 11:00 AM
Bobino
Apr 9, 2011 12:01 PM
DougsDyna
Apr 8, 2008 12:20 AM
carsoni
Jun 17, 2007 10:04 PM
StargazerXT12
May 24, 2007 04:59 PM
