Ohlins stripped threads
Old Sep 20, 2016 | 07:56 AM
'05Train's Avatar
'05Train
As mentioned, it's very important to clean them before you adjust them. I also spray some chain lube on them before I move the collars.
Old Sep 20, 2016 | 08:11 AM
grbrown's Avatar
grbrown
Good idea, I use it on all manner of non-bike things, having given up chain-drive bikes long ago.
Old Sep 20, 2016 | 09:44 AM
Ben221's Avatar
Ben221
Not sure about chain lube as from my experience it's very sticky and collects dust. I will use 3-1 approach but bet wd40 would work. You think some anti seize is a good idea.
Old Sep 20, 2016 | 09:54 AM
grbrown's Avatar
grbrown
True, but being thick it will fill the gaps between the threads. Any dust is likely to be kept outside of the threads. Any fluid is likely to attract dust. WD40 should serve fine as a penetrating fluid, to lubricate an unprotected thread. When I next adjust my shocks I'll clean them and try my chain lube!
Old Sep 20, 2016 | 10:04 AM
LoneRiderFLH's Avatar
LoneRiderFLH
Thinking out loud here as new shocks are on the brown truck. What about garage door lube? That stuff seems dry and no drip. Lubes chain, hinges and tracks very well with no mess and does not attract dirt. Easy spray on action. Ideal has a product at home centers
Old Sep 21, 2016 | 04:00 AM
mglax13's Avatar
mglax13
I posted a thread about this in the suspension section a few days ago. Howard replied and said to clean the threads with brake cleaner and apply Belray waterproof grease to the threads.
Old Sep 21, 2016 | 05:36 AM
valpal's Avatar
valpal
Hhm. Isn't the whole point of that chain lube to not attract dust/dirt?
I indeed put such chain lube on my threads before my latest (1100 miles) trip, and back home when I needed to adjust them temporarily for 1-up I cleaned the threads prior to moving the pre-load screw. For that we used WD40. The threads were dirty as we went through fairly dusty areas but also through a lot of rain (which might have actually cleaned off some of that dirt by the time we got back). Long story short: cleaning was a breeze and I cannot say that the chain lube hurt. But I also do not know if it in any way helped to prevent dirt from getting stuck...
One thing less preferable about chain lube: at least mine is a spray. For shock threads it's probably better to use something solid so you can use a brush to apply it. Because, how do you truly get all threads on the inside facing the bike when using a spray. You'll be spraying all over the place or miss quite a bit - and no, I will not take the shocks off every time I need to apply some sort of grease!
Old Sep 21, 2016 | 05:40 AM
grbrown's Avatar
grbrown
I've got so much redundant chain lube I'm always looking for other uses! All our external locks and padlocks are a recent application, as it keeps the moving parts protected and working.
Old Sep 21, 2016 | 06:10 AM
Goose_NC's Avatar
Goose_NC
So, Let me get this straight. People complain about the stock air shocks as too difficult to adjust. But you'll carry WD40 (or similiar) and a rag to lubricate the threads on these expensive shocks? Or, y'all never adjust for varying loads outside of the garage?
Old Sep 21, 2016 | 06:49 AM
grbrown's Avatar
grbrown
Don't make more of this than it really is! I've ridden longer and more miles on air shocks than my Ohlins. I never adjusted my air shocks that often, nor do I adjust my Ohlins often and I don't use WD40 on them. Short trips solo or 2-up with both air shocks and Ohlins were fine, I only readjust them for longer trips when 2-up and fully loaded.
