rubber mat [...] for the floor that the Bike sits on
What's your idea there? To alleviate/distribute the pressure on the tires? I don't know the mats you mentioned: How thick are they and how "rubbery"/soft are they? It's not like the stuff you can put under your, for instance, washing machine, right? Example: https://www.google.ch/imgres?imgurl=...act=mrc&uact=8
If you can, keep it in your garage on a tender. Get to know your bike, clean, repair, zip tie, and talk to it softly.. I mean,, ummm..
If you take it out on a nice day in the winter and your area puts salt on the road, you should spray the underside with a marine grade salt remover or an old biker friend that rides all winter, uses a cup of white vinegar to 2 gals of hot water to rinse with a sprayer. His bike still looks awsome. If you don't have the room
Fill 'er up with non oxygenated gas if available, add some stabilizer, put a battery tender on it. It'll be fine in the spring. That's all I've been doing for 45 years of biking and never had an issue. My shed isn't heated either. Gets down to -30 up here. Even if it kills the battery, the cost of winter storage at most dealers would get you a new one.
Wow. Thanks for all the responses. Seems like it's unanimous. Looks like I'll be keeping it at home where I really wanted anyway so I could hug it and rub it to let it know it's loved even when not ridden.
What about a cover? Indoor/Outdoor? Breathable? I'd kind of like one for when I ride to work and there's a chance of rain.
Also, I have a center stand. Is that enough to get the tires up?
A couple of times over the winter on a warmer day I will fire it up for 10 minutes just to get things moving.
More harm than good. If you are going to start it over the winter, you need to bring up to full operating temperature to allow the crankcase breathers to blow out any moisture. Water is a natural by product of combustion along with the fact that condensation forms over the winter (have you ever noticed during the winter, in unheated garage, your bike is wet?). The condensation that forms is not just on the outside. During the winter this can turn into slush inside your engine (including oil passageways). If necessary to fire it up, it has to get to full temp or you are adding to the problem - 10 minutes is not enough - if you ain't gonna ride it - leave her be.
Been storing bikes in non heated (Illinois) garage for years. I park bike on top of a sheet of plywood (plywood soaks up moister, put stabil in a full tank of gas, put on battery tender, cover it up and wont start it up until spring for first ride. Never a problem bikes have always started right up.
Glad you're storing it in your garage. The CON in having it at the dealer would be you can't sneak into the garage in the middle of the night and bond with your new baby.
I ride my bike into the garage, plug it into the tender, and go in the house. Nothing special.
Once the roads have salt on them and I know I'm not going to ride till spring, I don't start it, I don't cover it, and I don't lift it off the ground (well unless I'm going to work on something). I don't start it, because it won't get hot enough and create moisture in the engine. Covers will attract moisture to the painted surfaces, chrome, etc, and rodents. Tires are meant to be on the ground with the vehicle on it. I've never had flat sided tires, ever. Cat truck or bike. Oh, and no fuel additive bs either.
I cover mine with cotton bed sheets. When stored inside I want to keep the dust off the bike, but not get any condensation under a cover. My garage has an epoxy coated floor, so moisture coming up from the floor is not an issue so it stays either on the floor/jiffy stand or I might put it up on the lift table.
