Engine knock or stumble help!
Old May 25, 2007 | 10:22 PM
badlandr's Avatar
badlandr
Default Engine knock or stumble help!
Hey I noticed that when the motor is warm from idle if I give the throttle a quick twist the motor makes a knocking nosie or a stumble. It is a 2007 SG which has 3500 miles with V&H Fuel Pak, Ness BS with SE Touring Muffs.
I don't know if it did it before the FP or not the bike seems to be idleing a little low ~8K.
BTW what sould it be idling at 10K?
Has one hear this?? Is this something to be concerned with?
I haven't tried takeing the FP out of the loop yet but I may just to see if it still does it.
Old May 25, 2007 | 10:32 PM
Fireman44's Avatar
Fireman44
Default RE: Engine knock or stumble help!
8 or 10 thousand rpm is a little low?
Old May 25, 2007 | 11:00 PM
choochoo's Avatar
choochoo
yeah that's what I thought 8k = 8000 mine would blow up at that rpm.
Probably meant 800 rpm.
Yeah you might want the dealer turn it up a 100 or so.
Mines around 1050 depending on outside air temp
Uboofer
Jul 26, 2015 06:07 PM
bigheadted
May 9, 2015 06:47 AM
SCUD
Aug 14, 2009 02:13 PM
ko4qc
Exhaust System Topics
Jun 15, 2009 02:42 AM
bluesgub
Feb 25, 2006 01:49 AM
