Was headed to the Ozarks a couple weeks ago and hit a bird, i noticed the left headlight on my Road Glide was loose after the impact. I took the bezel off and the mount that holds the light was broken. I`ve looked on the HD site but I can`t find just the bracket and I don`t want to buy a new set of Daymakers just to get the bracket.
The part I am looking for is item #16, 67959-10 Trim Dual Headlamp. I have a 08 RG that I added the Daymakers to so I don`t know if that part would fit mine or not.
should fit fine. the parts fiche that I printed up is from the 2013 se roadglide which comes stock with daymakers. to compare, the same parts are on the 2012 roadglide custom that did not come with daymakers.
go to the harley website.
look up daymaker headlights for your model year.
go to the tabs under the item description
find the installation instructions
in the instructions is a service parts list, that shows everything that can be bought separately
find the part number you need
order it on line for best pricing.
pay shipping
install
ride
That's good information! I asked one time and I got the answer that HD probably doesn't sell that separately. So, I just bought the chinese daymakers for $150. Lesson learned!
Originally Posted by Hunter 1
Thanks guys I appreciate the help.
Did you end up ordering the part? Did it fit correctly?
