2014+ 4 point docking system???
Old Oct 16, 2016 | 08:17 PM
Hades02's Avatar
Hades02
Default 2014+ 4 point docking system???
Interested to hear from owners that have used an aftermarket 4 point docking system for 2014+ bikes. I would assume that if I use grade 8 hardware, I should have no problems. Not worried about perfect finish, just functional and safe.
Please do not comment if you don't have experience with the product. Hearing that it should only be a Harley part is not helpful. If that was the case we wouldn't have a DIY sticky.
Old Oct 16, 2016 | 08:38 PM
Idahokid's Avatar
Idahokid
I bought mine off eBay for $50 bucks or so.I watched you tube to put it together.The studs have to be pressed in the brackets.I feel safe using it.
Old Oct 16, 2016 | 08:55 PM
Eunoterpsia's Avatar
Eunoterpsia
I ran across set on Amazon (prime) and it was maybe 45... Same companies produce (essentially) the same product for my application and I am happier than a pig in a sloppy trough of alimentary waste.
Old Oct 16, 2016 | 08:56 PM
Hades02's Avatar
Hades02
Thank you. Not sure what you mean by the studs have to be pressed in. What seller did you buy from?
Old Oct 16, 2016 | 09:06 PM
Hades02's Avatar
Hades02
Just to clarify, by safe I mean with a tour pack on and a passenger. Like I said, I'm pretty sure the failure that would be detrimental would be the bolts shearing off either at the attachment point to the bike or the studs where the tour pack mount attaches. Using grade 8 hardware would eliminate this.
Old Oct 17, 2016 | 12:08 AM
sn95bullitt's Avatar
sn95bullitt
Drag Specialties sales them.
Old Oct 17, 2016 | 08:46 AM
Just Me's Avatar
Just Me
E-bay, $61.00 delivered. VERY satisfied.
Old Oct 17, 2016 | 11:09 AM
Hades02's Avatar
Hades02
Thanks everyone. Someone else started a similar thread so no need to answer anymore. Wish I could lock this as the same info is in the other thread as well.
Gonzy
Jul 1, 2019 10:54 PM
umassminuteman89
General Topics/Tech Tips
Dec 18, 2018 07:58 PM
Garemlin
Mar 22, 2018 05:04 PM
kpb46
Nov 3, 2013 06:21 AM
trafficjams
Aug 26, 2008 01:16 PM
