High beam lights
Old Oct 19, 2016 | 11:14 AM
ButterBean12's Avatar
ButterBean12
I installed a jumper on my 01 Road king had to splice it in but it worked well. On my 13 Ultra I just installed the plug in harness and it works fine, went to all led across the front also. Can't have too many lights I say....
Old Oct 19, 2016 | 12:51 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Too my knowledge, the P&A connector has nothing to do with the high beam (or the low beam). Since the spots are going out when you switch to high, that rules out the handlebar switch. If you are certain the bulb is good, test the connector for power then work backwards from there
Old Oct 19, 2016 | 04:35 PM
rhlhamlet's Avatar
rhlhamlet
That's exactly what they are supposed to do
Old Oct 19, 2016 | 04:58 PM
TriGeezer's Avatar
TriGeezer
The Op Clarified that the Hi beam dies not come on. This is what he described:
Switch. Lo beam Light. Hi Beam Light. Spots(,with spot switch on)
LO. ON. OFF. ON
HI. ON OFF. OFF
So, somehow the headlight isn't being switched from LO to HI.
Old Oct 20, 2016 | 02:29 AM
From_Behind's Avatar
From_Behind
The high beam is supposed to stay off when you turn the high beam on?
OP - there's something seriously screwed up there.
Old Oct 20, 2016 | 06:08 AM
Mikes145's Avatar
Mikes145
Use a voltmeter and start at the connector to the headlight and work your way back. Maybe you have a damaged wire?
Old Oct 20, 2016 | 08:23 AM
RKZen's Avatar
RKZen
Well, I guess my speed reading isn't worth a dang.
OP, is this the first time you noticed or the first time this has happened? Could be a faulty headlight. Bike still under warranty?
Old Oct 20, 2016 | 09:07 AM
Whodey's Avatar
Whodey
1st time tried high beam. I just wanted to make sure everything worked before I messed with it and glad I did. Yes its under warranty but if it was something like a simple fuse or relay don't really want to mess with dealership. I spent 3 hours there last weekend for them to replace a screw and washer that fell out of quick release.
Old Oct 22, 2016 | 09:08 AM
Nitro 54's Avatar
Nitro 54
Time for another wasted 3 hours. They do that so you will wander through the store and maybe buy something.
Old Oct 22, 2016 | 10:20 AM
14GuineaPig's Avatar
14GuineaPig
From what I can see in the wiring diagrams for your bike, the BCM controls power to both the High Beam (BE/W wire, position M3 in connector 242B) and Low Beam (BE/Y wire, position M4 in connector 242B) IMO that means a trip back to the dealer. The BCM is fed power thru the Main Fuse.
