Alarm Sensitivity
Old Sep 24, 2019 | 02:28 PM
K Melancon's Avatar
K Melancon
I just checked the 2019 Owners Manual Security section and could not find anything on adjusting the alarm sensitivity. I was going to set mine to go off if a gnat landed on the antenna.
Old Sep 24, 2019 | 02:40 PM
Hoginedgewood's Avatar
Hoginedgewood
I don't have an antenna, but I wanted the same effect.
Old Sep 24, 2019 | 02:44 PM
Hoginedgewood
Do you mean you added the H-D Smart Siren? Just turning the ignition on will not activate the siren well not on mine. If you Tyra moving the bike or starting the bike then the siren goes off. I have my siren set to silent so it only will blast when the security is set off. It remains quiet when it resets and turns off.
If I shake it violently it will churp, im going from an o6 that had sensitivity adjustment, these new fangled things are just insensitive
Old Sep 24, 2019 | 03:14 PM
Pantera99's Avatar
Pantera99
Really? My 09 Ultra Classic goes off if I just look at it wrong. Even w the key fob it will chirp at me a few times once in awhile. & touch the bike at all & it the alarm chirps a few times then goes nuts.
Old Sep 25, 2019 | 02:33 PM
woodthumb2's Avatar
woodthumb2
i gotta say.. this is one harley feature that i never quite understood.... the blinking dash light might be somewhat of a deterrent but otherwise... whats the use ? whenever i am on the road and stop for the night , i disable it so some kid wont rock on it and set of the lights, thus running battery down... happened to buddy of mine once... no harm done... just a curious somebody who probably sat on it, saw the lights, freaked out and took off.. next morning...dead battery
Old Sep 25, 2019 | 04:00 PM
Pothole914's Avatar
Pothole914
Must be something else wrong with your buddies bike. Mine stops the siren and flashing lights after about 2 minutes when the movement stops.
Old Sep 25, 2019 | 06:49 PM
skratch's Avatar
skratch
yeah, the lights aren't going to flash continuously until the battery dies. maybe the 'curious somebody' turned the ignition switch on also?
Old Sep 26, 2019 | 09:59 AM
K Melancon's Avatar
K Melancon
Check the flash pattern. The lights only blink together like twice when it sets. When the alarm is activated the left flash, then the right, then then left, then the right, then the left until it stops. If they both flashing together then your emergency flashers were turned on. Do another test and see
Old Sep 26, 2019 | 03:01 PM
woodthumb2's Avatar
woodthumb2
yes.. my mistake... that happened when he was towing the bike... not when someone played with it...
Old Sep 26, 2019 | 04:19 PM
Pantera99's Avatar
Pantera99
There is a transport mode. Ask me how I found out about it. 😂🤣
HDJIM1158
Milwaukee Eight (M8)
Jul 8, 2019 08:04 PM
Kevinch
2014-2024 Touring Models
Apr 11, 2015 07:01 PM
Talldog
Oct 30, 2013 09:21 AM
PanJH
Oct 18, 2012 08:48 AM
red33m
Jul 16, 2010 07:41 AM
