Race Gas
Old Oct 26, 2016 | 05:20 PM
qtrracer's Avatar
qtrracer
I'm not a big believer in an additive that claims to turn pump gas into race gas. Octane is not just octane as far as real racing fuel is concerned. Now having addressed that, there is probably no need for you to think a higher octane gasoline will help your miss/sputter in any way. You say you have a 95" but you decline to say whether or not you have changed your cams and/or exhaust and most importantly did you have the bike tuned after you completed the big bore and any other changes that were done? Most likely it just needs to be tuned.
Old Oct 26, 2016 | 07:25 PM
Sierra977's Avatar
Sierra977
Something to think about but winter-blend gasoline is being delivered in our area the last few weeks. Butane-blend winter gasoline is sewage.
Old Oct 26, 2016 | 08:58 PM
wscott's Avatar
wscott
Originally Posted by Darrin Loecker
Hello Boys,
Have or do any of you use the product Race Gas? I've had problems the last two times that I have ridden, when my bike feels like it misses or spits and sputters a little around the 2300-2800 rpm range. When I ride it hard, it runs great, but going about 70mph for a period of time I will get a missing, sputtering action??? I will also get it when I come to a stop, it idles fine, then I take off through 1, 2, and 3 and I will hold it in third gear about 2700rpm and it will do the missing/sputtering thing...I will go through the rest of the gears and it will run fine? No codes, new spark plugs, and it's a 95" build...Just thinking is this product might help...Thanks!
You bike/motor has a mech & or tuning issue (or both!) that needs to be addressed that no additive can fix.
Get your bike to a pro that knows what they are doing to fix your ride.
Scott
Old Oct 26, 2016 | 09:00 PM
wscott's Avatar
wscott
True but it should not make a bike/motor perform as poorly as his motor/bike is at times,thats for sure.
Scott
Old Oct 26, 2016 | 09:18 PM
voodoodrug's Avatar
voodoodrug
tried it once and bike liked it to a degree. ran cooler but i have already managed that issue. seemed to run a slight bit better over all but maybe thats cause it was 7.99 a gallon. nope its not worth it.
Old Nov 16, 2016 | 10:02 AM
Darrin Loecker's Avatar
Darrin Loecker
Hello men,
I think we have resolved the problem, I had a small hole (bigger than a pin hole) in my fuel line that was connected to the regulator. I had them replace all lines and filter and the problem is fixed for now! Thanks for all the replies.
Old Nov 16, 2016 | 03:09 PM
wscott's Avatar
wscott
Hello Boys,
Last edited by wscott; Nov 16, 2016 at 03:11 PM. Reason: opps,just realized this is an old thread someone brought back i already posted in.
Old Nov 16, 2016 | 03:13 PM
wscott's Avatar
wscott
Hello men,
Well thanks a lot for taking the time to post the outcome/fix for the problem so others can benefit from it which doesnt always happen.
Scott
Old May 5, 2017 | 02:54 PM
Darrin Loecker
Updated from last post...well the problem still exists...after changing spark plug wires, new injectors, time on dyno, calling tuner that tuned the bike and the engine builder, FINALLY I believe I solved the mystery...I did extensive reading and research and found that I may need to switch out the TPS and I believe this has fixed the problem. Expensive lesson to learn, my Harley Dealership told me that they can replace it, but it won't help. Well, I told them to do it anyway and it ended up fixing the problem. Hopefully this is the end to the gremlins for now!
Old May 5, 2017 | 02:58 PM
danzio's Avatar
danzio
Hello Boys,
If it's EFI, it's probably tune related.
Edit: Didn't read your last post. Glad you solved it.
