Installing Progressive Monotube - 1 spacer or two?
Old Oct 26, 2016 | 08:27 PM
TwoBlue02's Avatar
TwoBlue02
Default Installing Progressive Monotube - 1 spacer or two?
Should be here Friday and taking the bike to my indy for install. I have read varying opinions about the number of spacers. Seems like instructions call for two but many saying this is too stiff.
I weigh in at 180 and wife is probably close (I don't ask). Most riding however is solo.
Input from you guys who have them?
Old Oct 26, 2016 | 11:38 PM
Neil's Avatar
Neil
I am running two clips. That said, is it stiff? Yes, but, I like it. Little brake dive test soaks up jarring bumps with no bottoming. Compared to stock suspension on my '16 work motor things are really tightened up. Bike is 02 Ultra, Tour Pak off mostly and almost all solo. I run around 215. I and see how some would say too stiff, like everything matter of preference. I have no experience with just one clip but imagine it would still be stiffer than stock which is an improvement. Good luck.
Neil
RDMC
Old Oct 27, 2016 | 12:06 AM
BB59's Avatar
BB59
I'm running 2 clips on my RK and it is pretty stiff. I weigh around 280 however so it is about right for me. My son weighs in at about 205 and felt that 2 clips was a little stiff for his liking. I removed one and he really likes the way it feels
Old Oct 27, 2016 | 12:17 AM
SnoRider's Avatar
SnoRider
I'm your weight I have zero. I would go with 1
Old Oct 27, 2016 | 05:50 AM
dajogejr's Avatar
dajogejr
I'm 250, still went with 1. Passenger weight has little to no affect on the fronts.
Brake dive, or lack thereof, is one of the first things you'll notice.
They will break in after a few thousand miles.
Still nowhere near as good as the ohlins out back...lol.
Old Oct 27, 2016 | 12:43 PM
Billman812's Avatar
Billman812
I think I ended up with 1 on my '97, not sure though.
I did not buy them directly through Progressive but they were full of answers when I had questions, including how to set up based on weight and terrain.
Sure rode better though!
Old Oct 27, 2016 | 02:31 PM
tsigwing's Avatar
tsigwing
I am 180 and followed progressive's instructions, believe it was 1.
Old Oct 27, 2016 | 04:19 PM
tinsnips's Avatar
tinsnips
getting ready to do my front end as well on my 08 ultra. anyone using the spring set up as opposed to the monotubes?
Old Oct 27, 2016 | 04:28 PM
sanman4ever's Avatar
sanman4ever
1 clip....do the job one time.
Old Oct 27, 2016 | 04:41 PM
wolfman 66's Avatar
wolfman 66
I used two when i put them in. I was at 260 lbs. it was too stiff. i am now 220 and it is way too stiff. i think i will take it apart and remove 1.
