5.37 gal fill-up
Old May 29, 2007 | 03:12 PM
dgriffith's Avatar
dgriffith
Default RE: 5.37 gal fill-up
My light will come on and I,ll ride another 20/30 miles then I might get 4 gal. in mine!! Been that way since new.
Old May 29, 2007 | 03:20 PM
sleepneagle's Avatar
sleepneagle
there is going to be a variance in tank size. it is stamped out and welded. I have taken 5.25 gallons before.
Old May 29, 2007 | 03:25 PM
freid's Avatar
freid
Stage III
I'll bet the pump is not calibrated properly. Imagine all the extra cash he makes on the overage?
Old May 29, 2007 | 03:34 PM
RE AND CHERYL's Avatar
RE AND CHERYL
Most I've ever put in it was 4.8 gallons. Light had been on for 20 miles or so.
Re'
Old May 29, 2007 | 04:47 PM
04RoadKing's Avatar
04RoadKing
I've seen pumps off many times. Just afew weeks ago I was filling up a 1 gallon gas can for my weed eater. I was using mixed gas so I wanted exactly 1 gallon. When the pump read 1 gallon I only had .750 in tha gas can. I went in and told the manager and he didn't beleave me. I make sure I don't ever full up my truck at that station.
Old May 29, 2007 | 04:52 PM
iclick's Avatar
iclick
ORIGINAL: Professor
I just filled up my 01 FLHTCI and it was still running (a little rough). The book says 5.0 gal capacity and it took 5.37 gallons! Either the pump is wrong, which the deadhead working at the station couldn't respond to or these things take more gas than the manual says. If you're wondering why I let it go that long it's because at 35K I thought it was time to replace the fuel filter and had the dealer do it yesterday. My fuel gauge registered 1/2 full and my warning light never came on. Back to the dealer. Is this why we wrench ourselves?
The FLH gas tank has been 5.4-gal. capacity for over a decade, though for some odd reason HD always specs it at 5.0 gal. I measured my '96 RK quart by quart one day and arrived at this conclusion. You were riding on fumes when you rode into that gas station, Prof.
Old May 29, 2007 | 04:57 PM
murph3204's Avatar
murph3204
I'd report that to the attorney general in your area. It sounds like the station owner has been doing some recalibration on his own.
sandrooney
Milwaukee Eight (M8)
14
Oct 31, 2018 07:50 AM
rock2r
Aug 25, 2014 08:54 AM
mplecha
Jul 26, 2009 09:54 AM
edilgdaor
Apr 13, 2007 10:19 PM
PSO169
Aug 8, 2006 02:53 PM
