Brake light stays on
Old Nov 17, 2016 | 04:43 PM
blackflame's Avatar
blackflame
Ok replaced the rear brake switch and the light still stays on??? Where to go next? Like I said before the front switch does click the relay when pushed in and out.. is there a way to by pass the rear switch, I always use my front. Stupid question how do you remove the light bulb before I do something I'm not supposed to do.. I did unplugged the rear switch and the light stayed on tested the 2 wires both had power???? Want to ride this weekend...
Old Nov 17, 2016 | 06:29 PM
RANGER73's Avatar
RANGER73
The rear switch has 2 wires, disconnect 1 and put a zip tie around the 2 to hold it in place.
If the light still stays on its the front switch or the relay.
Mine doesn't have a relay for the brake light.
Old Nov 17, 2016 | 06:46 PM
blackflame's Avatar
blackflame
Thanks,, do you know how to test the front switch? But if the front switch was bad why is it still clicking the relay?
Old Nov 17, 2016 | 08:34 PM
RANGER73's Avatar
RANGER73
Could be the relay is clicking and not breaking contact internally.
Old Nov 17, 2016 | 08:37 PM
RANGER73's Avatar
RANGER73
The switch is normally closed switch. So it opens when pressed, Try pushing on the button with a screwdriver, but be careful.
Old Nov 18, 2016 | 06:48 AM
blackflame's Avatar
blackflame
[QUOTE=RANGER73;15687957]The switch is normally closed switch. So it opens when pressed, Try pushing on the button with a screwdriver, but be careful.[/QUOTE
I have the lever off and just pressing with my finger, can I test the front switch with it on the bike. Started yo open up the controls last night...
Old Nov 18, 2016 | 08:38 AM
roussfam's Avatar
roussfam
[QUOTE=blackflame;15688699]
If the brake light goes off when you press the front switch with your finger then the tit has broken off and needs to be extended, screw or JB Weld, or replace switch. I didn't see it mentioned but did you have your bars off recently?
Old Nov 18, 2016 | 09:27 AM
RANGER73's Avatar
RANGER73
[QUOTE=roussfam;15688987]
I was going there next, but was puzzled that the "relay" was clicking when he pressed the lever
That would indicate the witch was working, so the "relay" maybe fused or there's a short. Maybe the filaments in the bulb fused together.
Did you replace the bulb yet?
Old Nov 18, 2016 | 10:37 AM
blackflame's Avatar
blackflame
, [QUOTE=RANGER73;15689185]
No haven't replaced the bars, it the front switch is clicking the relay does that mean its ok and I should check the relay, bulb looks good all wires are still connected no broken wires. But how do I get the bulb out? I see the two tabs but nit not what they do, might have to ride tomorrow with it on.
Old Nov 18, 2016 | 05:50 PM
RANGER73's Avatar
RANGER73
What tabs? A picture would help. There's usually 2 screws.
