Vibrations
Old Nov 22, 2016 | 01:10 AM
Leevi's Avatar
Leevi
Stage III
Default Vibrations
I many threads all kind of vibrations is the issue. There might be a lot of reasons
behind but in my case it was a dry bushing. I have a SGS 2015 and from the day one I had bad vibrations - like Sportsters before rubbermounts. Finaly after
12 months we found the reason. The front engine stabilzer bar bushigs were
dry and were not able to work accordingly. Couple drops of oil and the bike was
smooth as silk! So next time you get extra vibrations check the stabilizerbar
bushings.
Old Nov 22, 2016 | 05:22 AM
grbrown's Avatar
grbrown
Thumbs up
Hi Lasse and welcome to HDF from the UK, just across the North Sea! Great tip and thanks.
Old Nov 22, 2016 | 01:05 PM
wscott's Avatar
wscott
bushings.
Your ref the stabilizer bar thats attached to the frame on 1 end & the other 2nd end is attached to a bracket (over front valve/rocker cover) thats mounted on the front cyl close to ex port,correct?
Scott
Old Nov 23, 2016 | 01:03 AM
Leevi's Avatar
Leevi
Stage III
Default Vibrations - front engine stabilizer bar
Yes, that's correct. I have heard that some call that stabilzer bar "dogbone"
which remains the shape. In each end there is a eye with a bushing. They
must be oiled to be able to move and stabilize vibrations. In my case the difference was night and day Wien dry or oiled.
Old Nov 23, 2016 | 04:00 PM
wscott's Avatar
wscott
Thanks for the clarifying that & letting us know your experience with it.
Anything we can do to reduce engine vibration & or noise from vibration so easilyby simply using a little bit of lube/oil is a good thing for sure.
So after reading your post i am going to include lubing the dogbone/stabilizer joint as reg maint item since you got such a positive result post doing it.
Thanks again.
Scott
Old Nov 23, 2016 | 04:04 PM
grbrown's Avatar
grbrown
Wink
Thanks again.
Scott
A good plan. If you have a typical dresser gear shifter linkage, lube the ends of that at the same time! I have one of the s/s Harley aftermarket ones, which has similar small swivels at each end.
maKINGwaffles
Jun 8, 2020 07:16 AM
N-Truder
Apr 12, 2015 04:49 PM
Southcity
Sep 13, 2012 03:34 PM
Turbo3pt3
Aug 16, 2012 05:45 PM
junebug69
Jul 18, 2011 08:04 PM
