Check Eng Light
Old Oct 6, 2005 | 01:03 AM
darrelld's Avatar
darrelld
Stage III
Default Check Eng Light
Need a little help - I have an '03 RK. We went on a 600mile trip last weekend and my speed sensor went out. I've installed a new one but the check eng light still comes on a few seconds after start up, then it goes back out. Is there a way to check the codes and then clear them? I've looked up this subject in the search and tried to do the diagnostic check but it doesn't read on my odometer. Is there a certain way to do this on my '03 FLHPI?
thanks
[IMG]local://upfiles/3984/B1DE69C4B6984B978125AB1ACCA2ECF8.jpg[/IMG]
Old Oct 6, 2005 | 02:15 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Check Eng Light
you can usually disconnedt the positive battery post for about 1 minute and it should clear all codes. it did on mine!
Old Oct 6, 2005 | 07:23 AM
pointswhat's Avatar
pointswhat
Good write up in the tech section heres a link
Old Oct 6, 2005 | 08:48 AM
Anthony8858's Avatar
Anthony8858
The prior code is stored in memory, and you need to reset it.
Here's how:
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
Have fun.
Old Oct 6, 2005 | 11:03 AM
Wally's Avatar
Wally
My 99' ultra has the oldstyle odometer. Is it possible mine will clear by removing the battery post like mikeisglidn.
Old Oct 6, 2005 | 05:29 PM
screamn_eagle's Avatar
screamn_eagle
I DO IT THE EASY WAY, I GO FOR A RIDE STOP INTO MY LOCAL DEALER AND TELL MY SERVICE ADVISOR,"STEVE I F'ED UP AGAIN AND MY LIGHT WONT GO OUT" HE WALKS OUTSIDE WITH ME RESETS IT AND AWAY I GO...LOL GOTTA LOVE A GREAT SERVICE ADVISOR.[8D]
Old Oct 7, 2005 | 12:26 AM
mikeisglidn
ORIGINAL: screamn_eagle
he doesnt love you anymore!!
semiret
Jul 20, 2021 12:39 PM
dplantz
May 9, 2014 09:10 PM
jojeda
Aug 21, 2012 11:18 PM
69cj
Feb 22, 2011 04:34 PM
Pops Road King
Apr 10, 2010 02:05 PM
