justme
Old Aug 21, 2012 | 10:54 PM
jojeda's Avatar
jojeda
Stage IV
Default justme
07 street glide. Just had check engine light flash briefly when i shut her off. It did not illuminate while it was running. Should i be concerned? If so what to do? Lil anxious
Old Aug 21, 2012 | 11:15 PM
jojeda's Avatar
jojeda
Stage IV
Ok guess ill figure it out
Old Aug 21, 2012 | 11:18 PM
wtb3886's Avatar
wtb3886
Use the search here and look for DTC, if there are any stored codes you will be able to see them and go from there.
pswomack's Avatar
pswomack
Give this a try and see if you have any Diagnostic codes stored.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
semiret
Jul 20, 2021 12:39 PM
mike08sg
Apr 4, 2011 10:59 PM
69cj
Feb 22, 2011 04:34 PM
FloridaFLHX
Aug 28, 2010 10:51 PM
darrelld
Oct 7, 2005 12:26 AM
