Fairing screws
Old Dec 13, 2016 | 10:49 AM
mayhem912's Avatar
mayhem912
Default Fairing screws
Good day all. I was trying to take my front fairing off, (2011 Electra glide} and while removing one of the three screws that hold the windshield in place, one of the screws pulled the nut out of the inner fairing. What can I use to put it back in place? Should I use a glue or a two-part epoxy? Thank you
Old Dec 13, 2016 | 10:50 AM
CGLTD's Avatar
CGLTD
Default Cgltd
I've use two part expoxy. Just need a little bit while being careful not to fill the threads with the glue.
Old Dec 13, 2016 | 10:59 AM
craigffb's Avatar
craigffb
Go to your local HD shop and ask for a couple of these: part # 16585-96
They are cheap. Do a search on here and you'll find pics and instructions on how to use them.
Old Dec 13, 2016 | 11:33 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Welcome to the club!
You are not the first and won't be the last. Those bronze inserts mentioned able are the cats meow.
Good luck.
Old Dec 13, 2016 | 01:21 PM
LQQK_OUT's Avatar
LQQK_OUT
Threaded insert kit, part number: 16585-96 as mentioned above. Instruction sheet attached.
File Type: pdf
Old Dec 13, 2016 | 03:52 PM
Bowhunter61's Avatar
Bowhunter61
ebay has this with the insert tool
http://www.ebay.com/itm/H-D-Batwing-...25.m3641.l6368
Old Dec 13, 2016 | 04:13 PM
e6fmf's Avatar
e6fmf
....go to lowes/home depot and pick up "T" nuts that fit your screws, CAREFULLY install windshield and fairing, ALL THE WHILE leaving a small gap for a drop or two of super glue to hold, tighten, allow to set overnight, disassemble next day, re-enforce "T" nuts with caulk or glue. Never have to worry about them again....
Old Dec 13, 2016 | 07:14 PM
1957buick's Avatar
1957buick
I used a 2 part epoxy called all craft from a good plumbing supply , water proof and easy to use , clean everything with brake clean put a longer bolt in the insert with grease on the bolt threads mix a little epoxy put in the hole , tap in the insert , let it dry 1 hour , then remove bolt and you are done forever !! This epoxy has never failed me no matter where i use it including my jet ski !
Old Dec 13, 2016 | 10:48 PM
Mr. Mike's Avatar
Mr. Mike
JBWeld on two fairing nutserts so far. Works great!
Old Dec 14, 2016 | 12:12 AM
2AMGuy's Avatar
2AMGuy
Most importantly, don't over tighten the screws when you put it back together.
"Snug" is good. Check them in a few days to make sure they're still "snug".
