Zddp
Also, While most know of ZDDP, there are other minerals in motor oils that replace ZDDP, such as Boron, etc. Where the cams go flat is more the way they are lubed. ZDDP provides a plating barrier between the parts, whereas newer oils do not provide that. If you took a flat tappet cammed engine, started it and continuously ran the engine until failure, the cam would show normal wear. Its the stopping, and oil dripping off the parts, that cause that dry startup issue that ZDDP took care of.
So when does the aging process start? Answer: There is no way to tell how old oil is without a manufacturing date stamped on each container.
It is nothing more than a guesstimate at best IMHO
B Bop
B Bop
Appreciate your efforts though!
B Bop
This generates more questions than answers.
If there is a shelf life for synthetic Mobil 1 oil, then you would think it would be stated somewhere on the label or stamped on the bottle, correct? To have an expiration date, each quart of oil should have a manufacturing date stamped somewhere to correlate the expiration date correct?
I can’t find anything on the label supporting your statement, you would think that would be very important information.
I’m not doubting your statement, you’re just the messenger. I’m questing its validity. Did this person have a name or title to follow up on?
And yes each bottle of oil should and does have a manufacturing code stamped on the bottle. I just checked two of my Mobil-1 15W-50 5-quart jugs and they both have a date code stamped on the jug. You have to look closely to see it. Mobil 1 prints the codes using laser dots instead of ink, cut into the product container. The two jugs I looked at have the following code
11016G29A ---> 29-July-2016
11014H19A ---> 19-August-2014
B Bop
It’s time to move on.
............................Check again, check again, and again....
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
This thread made me wonder about the oil in my motor
Redline 20W60
Redline specifies zinc as 2125ppm and phosphorus as 2100ppm
https://www.redlineoil.com/product.aspx?pid=111&pcid=13
Redline 20W60
Phosphorus level, PPM is: 1600
https://mobiloil.com/~/media/amer/us...guide-2016.pdf
https://mobiloil.com/~/media/amer/us...guide-2015.pdf
Its time to move on.
Mobil 1 Racing 4T 10W-40 @ $10.99 per quart
Mobil 1 V-Twin 20W-50 @ $10.99 per quart
I checked a number of the above mentioned products on the shelf, and they all had a manufacturer date code on them. Some of the codes were a bit difficult to read.
Mobil 1 Racing 4T 10W-40, manufacture code: 10116D30A (April 30, 2016)
Mobil 1 V-Twin 20W-50, manufacture code: 10116F04A (June 4, 2016)
I've attached a picture to show where to look for the Mobil 1 manufacture code. You need to tilt the bottle and look closely under a fairly bright light.
Maybe the above person and his buddies are inebriated.
