Starter suggestions
Old Dec 30, 2016 | 01:32 PM
wscott's Avatar
wscott
Originally Posted by lizard86
Thank you for the advice. My charging system is working as it should. I will upgrade the battery and cables as I feel the cables are probably due anyway. They have been on the bike since I have had it (almost 4 years). Now I just need to decide on a starter. Looking at the all ***** 1.7 and the Terry Components 1.8 or 2.0. The Terry Components starters require a spacer for the oil fill spout but I have no problems installing that as well if they will be better in the long run than the all ***** starter.
NP!
Please dont forget to post a followup here in this same thread on how the new battery,hvy duty battery cables & hi trq starter work out on your hi 10.5 compression motor.
Suggestion,with 10.5 compression that will likely create more engine heat in summer cond it would also be a good idea to install (if haven't already done so) an oil cooler with elec cooling fans (Ultracool oil cooler) & Wards cooling fans both at the same time like i did on my 2009 FLHTCU a few yrs ago.
An oil cooler without elec cooling fans is much less efficient (just about useless!) due to lack of airflow when sitting still @ stoplights in 90deg f summer heat and or when @ slower road speed in slow moving traffic.
Both those cooling mods working together as a hi perf cooling team reduced oil temp a whopping 50deg f in 90= deg f summer heat which was huge improvement in overall engine perf & rider comfort .
And keep in mind its the oils job to also cool the motor by removing heat from it so when oil temp is reduced 50deg f in summer heat engine temp is also significantly reduced @ the same time too.
The 50deg f reduction in oil temp in summer cond my HD's motor got stopped the detonation it used to have at times under load ,increased oil pressure a solid 10-12psi @ idle & cruise too,made valvetrain quieter,less heat from motor hitting riders,motor now retains most of the pwr/trq & crisp throttle response it used to always loose in warmer summer cond,and more.
Good luck.
Scott
Gibler77
Sep 18, 2016 05:11 PM
harley_jeff
Exhaust System Topics
Jul 17, 2013 08:04 AM
wfbailey06
Sep 10, 2010 01:54 PM
deerslayer1543
Custom Models
Aug 23, 2010 01:07 PM
98 FLHX
EVO
Feb 13, 2010 02:20 PM
