cam install
Old Jan 21, 2017 | 11:18 AM
DanDman's Avatar
DanDman
If you have the spring loaded tensioners there will definitely be some resistance. I also have a '00 with 570 cams and did the the hydraulic tensioner upgrade and when the cams & cam plate are installed it had slight resistance. My cam lobes didn't hit the case, but you should double check, all installs don't go the same way.
Old Jan 21, 2017 | 11:22 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by DanDman
If you have the spring loaded tensioners there will definitely be some resistance. I also have a '00 and did the the hydraulic tensioner upgrade and when the cams & cam plate are installed it had slight resistance.
Unless I misunderstood...he's talking about an inconsistent resistance
Originally Posted by streetking1
... I have done cam upgrades and reacement on Evo and twin cams but this is actually the first time I have actually checked rotation at this point of install.
The thing that concern me is the resistance is in just a certain spot in the rotation. Have checked all clearances and pretty much anything that I can think of and have come up empty.thanks again
Old Jan 21, 2017 | 11:44 AM
DanDman's Avatar
DanDman
Didn't catch that resistance was more pronounced in one spot. Was the cam bearings retaining plate installed?
Old Jan 22, 2017 | 01:50 PM
Eastcoast Jim's Avatar
Eastcoast Jim
I had to clearance the case on my 03 with a .575 lift cam - then again for .590. - defiantly check the clearance
The problem you are describing sounds like a gear drive too tight - but you are chain drive - so ?? Eastcoast Jim
Old Jan 22, 2017 | 01:55 PM
streetking1's Avatar
streetking1
6th Gear
Ok , thanks for your knowledge it is appreciated .
I just wanted to get some more input before I moved on.
Old Jan 22, 2017 | 02:05 PM
Apendejo's Avatar
Apendejo
Go to the search function, at the very top of the page where the down arrow is click on it, click "all", type in Hippo Build.
All the information you will ever need to build a 95" .570 cam motor.
Old Jan 22, 2017 | 02:22 PM
streetking1
6th Gear
Will do. Thanks
streetking1
Engine Mechanical Topics
Jan 22, 2017 12:17 PM
2006ultra
Mar 12, 2015 08:46 AM
RKRider63
Exhaust System Topics
Mar 5, 2013 05:54 AM
rags
Oct 31, 2009 02:34 AM
BUSTERK
27
Aug 26, 2009 12:32 PM
