Front wheel too much drag
Old Feb 8, 2017 | 07:21 PM
CarlB's Avatar
CarlB
The front brakes stop the bike very well and I've felt the ABS kick in before so I know it's working. I think it's that the pistons aren't returning at all on one side.
Old Feb 8, 2017 | 08:31 PM
Juan L's Avatar
Juan L
Moderator
You at least know which one of the pistons is not returning, it is the one with the worn pads.
Old Feb 8, 2017 | 08:42 PM
Keithhu's Avatar
Keithhu
Is there a rebuild kit for the brembos? I thought I saw a thread complaining that they dont exist.
edit - looks like you can put something together.
See if there's anything helpful here - https://www.google.com/search?q=harl...e:hdforums.com
Old Feb 8, 2017 | 08:57 PM
Mr-Mike's Avatar
Mr-Mike
It's not really that bad. If you got just a little more spin, I would say welcome to no-floating or semi-floating rotor/discs. For the hell of it, make sure the rotors true and aligned. Definitely do the rebuild - it's easy, it's fun, it's cheap. Those pistons look pretty grimy.
Old Feb 8, 2017 | 09:19 PM
leon anthony's Avatar
leon anthony
pistons do not return the is no spring to return them unlike brakes shoes with return springs. when you release the brake lever you just release the pressure on the pads
they stay right there just no pressure on them
Old Feb 8, 2017 | 09:21 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I would flush the entire system very well, and ride it.
Reevaluate the system later, if needed.
Old Feb 8, 2017 | 09:22 PM
CarlB's Avatar
CarlB
My FLSTS is a no-float and spins free. With a DIY rebuild, how do I bleed the brakes without a digital technician? Trailer it to dealer?
Old Feb 8, 2017 | 09:25 PM
CarlB's Avatar
CarlB
Dealer rebuilt the master cylinder and flushed fluid. Symptom persists which is why I'm trying to address it this winter.
Old Feb 8, 2017 | 10:16 PM
SIDECAR BOB's Avatar
SIDECAR BOB
disc brakes have some drag at all times, with disc they should not spin freely, the pads are always in contact with the disc. How much drag is too much is hard to describe, you should be able to turn the wheel easily by hand and the drag should be constant no hard to turn less effort to turn areas. That being said from the pictures you pistons in the calipers look corroded and could very well not be sliding back as others said , rebuilding the calipers is easy and pretty cheap to do but either replace the pistons or make sure the clean up well with no pitting or roughness. if the wheel spins easily then up you may need to check for rotor warpage. Hard to expl;ain maybe find a indy or dealer you trust to double check your brakes and see if they think the drag is excessive.
Old Feb 8, 2017 | 10:30 PM
bklynbob's Avatar
bklynbob
What's the runout on the discs?
