I have a question about a chirp sound I have. Everytime I crack the throttle, either after each upshift or just when acceleratingafter decel.
Ihave to hit the throttle a little aggressivly to get it to make this chirp sound. Sounds like it's coming from front (?) of engine.
Has anyone experienced anything like this? I have a '07 Ultra with the 103 Stage II, V&H True duals with V&H Ovals.
Next check your saddlebags. I'm not certain if the 07's are the same as earlier models however the saddlebag would rub the saddlebag support rail underneath it. Pull the bag and look at the bottom back side of it. Look for rub marks on the actual bar. Takes only a minute or so to rule it out.
