Crank case seal
Old Feb 10, 2017 | 12:50 PM
cowboybob56's Avatar
cowboybob56
Default Crank case seal
My stator plug was leaking, so I RTV'd it. Now my primary is leaking. Trans is a different color. I'm beginning to wonder if the seal has just fallen out. Do I just pop the clutch cover to lower the level and wait until another issue causes me to open it up and replace the seal then?
Old Feb 10, 2017 | 01:19 PM
RK_Classic's Avatar
RK_Classic
Is is leaking from the clutch cover or the outer primary cover? Dunno what bike you have but on my RK their is a rubber gasket behind the clutch cover.
rk classic
Old Feb 10, 2017 | 04:30 PM
Ducky 149's Avatar
Ducky 149
Oil can and will migrate from engine side to primary side on EVO motors. Not positive about Block Heads though. Check engine oil level, may be low. When mine was leaking quite a lot of oil would go into primary. Caused clutch to drag, made shifting hard. I was on a road trip trying to get home, so I would keep motor side full and dump from derby cover. Good luck!!
Old Feb 10, 2017 | 06:07 PM
silveradoman2's Avatar
silveradoman2
[QUOTE=Ducky I was on a road trip trying to get home, so I would keep motor side full and dump from derby cover. Good luck!![/QUOTE]
Man that must of been a mess... Probably got all over the rear tire
How much oil did you go thru before you made it home?
Glad you made it safely
harley7316
Feb 20, 2015 01:22 PM
riverbayhunt
Jan 24, 2010 06:54 PM
jsp
General Topics/Tech Tips
Nov 28, 2007 08:42 PM
wideopen
Aug 27, 2006 10:42 PM
KBES BAGGER
Nov 27, 2005 01:47 AM
