Build help
Old Feb 10, 2017 | 11:02 PM
fmawyer's Avatar
fmawyer
Default Build help
I've got a 2006 Electra glide 88" only upgrades are
Big sucker
PCIII
Rinehart true duals
Question is,I can get a set of 103 screamin eagle heads from a 2005 for a very good price.I plan on doing the 95" big bore and cams maybe S&S 585 easy starts.Should I buy the 103 eagle heads or just use what I got.Thanks in advance for any advice
Old Feb 10, 2017 | 11:31 PM
Bingee's Avatar
Bingee
The 95" build should be setup with the original equipment heads. There's no advantage for the 103 heads on a 95" nor is it recommended.
Old Feb 11, 2017 | 12:15 AM
fmawyer's Avatar
fmawyer
Thanks for the info
Old Feb 11, 2017 | 03:21 PM
0ldhippie's Avatar
0ldhippie
You would be much better off having your heads done to match your build.
speakerfritz
Nov 17, 2016 09:19 AM
Hoytman1968
Engine Mechanical Topics
May 29, 2016 07:21 AM
superstandardFL
Sep 23, 2009 06:34 PM
giddiup
Exhaust System Topics
Feb 16, 2007 02:23 PM
drdave
Feb 2, 2007 12:34 PM
