cylinder heads
Old Sep 23, 2009 | 10:23 AM
superstandardFL's Avatar
superstandardFL
6th Gear
Default cylinder heads
have a 2007 FLHT which i have put a 103" screamin eagle kit in ,with 255 cams, power commander, rinehardt true duals, and the screamin eagle breather. looking for heads now to compliment the set up. Will the screamin eagle 110 plus heads work on this without modification? orshould i go for stock heads with work? also will the heads off a 2006 bolt direct on and only maybe do some porting , bigger valves maybe take a bit off to gain compression. add comression relesase etc. any ideas or direction guys would be appreciated. i dont want to touch my stock heads unless i really have to as woul dbe nice to have for back up. i can have acces to both the 110 screamin eagles and the 2006 stock heads for resanable money. i know the motors 88 to 96 is mostly a stroke issue thats whay wondering about compatibility of the cylinder head thanks in advance aloso i guess one last thing should i stick with the 255 cams or go to somethign little bigger may 258 or something the set up in bike right now runs only 78 HP on dyno but must have gobs of torque as it works as well as a buddies who dynoed right before me with 97
Old Sep 23, 2009 | 10:32 AM
gabulldog's Avatar
gabulldog
My experience with the TC engine is that the heads are probably the most important item to get "real" power from the engines. I don't think it is a big deal if you go with the Screamin Eagle heads or heads from "Branch" - "Head Qtrs" ,etc. I will say go with a reputable head guy not just a guy in a shop with a die grinder. They are going to be $6-800 for the machine work + cores no matter who you use. Good Luck, Make sure your parts /head work / etc. match your riding style.
Old Sep 23, 2009 | 03:39 PM
gunnert's Avatar
gunnert
Those 255 cams do not warrant the expense of bigger valves and extreme porting or polishing. You'll be very happy with a mild porting only of the heads. You should be able to get by with around $300 max. The 06/07 heads are the same.
Old Sep 23, 2009 | 04:03 PM
qtrracer's Avatar
qtrracer
The SE heads that you mention need matching SE pistons to match the combustion chambers or the comp ratio will be way off . Just pay the core charge to a reputable head guy so you can keep yours until you get the ported ones if you want to.
Old Sep 23, 2009 | 04:09 PM
Firetender's Avatar
Firetender
I'd never put out-of-the-box SE heads on my bike without having them gone through, but that's just me. And I would not change out the heads without installing mid-lift cams at the same time to save the expense of labor and tuning costs.
Old Sep 23, 2009 | 05:53 PM
jag1886's Avatar
jag1886
You've already headed down the wrong road you will probably have to at least change the pistons, cam and have the heads ported top get good performance.
Harley heads are almost to big to start with for street bikes and the SE heads are even worse unless you are cranking the throttle all day long.
Old Sep 23, 2009 | 06:13 PM
emwolb's Avatar
emwolb
check out bigboyz head porting in augusta maine. their site is impressive, and will show you a ton of information as to why you want to stay away from 05 and earlier heads for several reasons. from the information and pictures in their site, it looks impressive the work they do. that being said, good old hanks mule rentals and harley head porting down the road can come up with an impressive website nowadays. beware. watch out for the guy who has a die grinder and some abrasive flap wheels who wants to experiment with your heads. everything has to work in concert to reach that sweet spot of a great running harley that is still as dependable as stock.
Old Sep 23, 2009 | 06:34 PM
Firetender's Avatar
Firetender
Emwold is correct, don't go with just anybody out there when you have your heads, S&S, or SE heads ported. I used Dick O'Brien's protege, who just happens to have a shop down the road and has more work than he needs. Who's Dick O'brien? Dick O'Brien was Harley-Davidson's highly successful racing manager from 1957 to 1983. Under O’Brien's direction, Harley-Davidson factory riders won 16 AMA Grand National Championships. He also oversaw the development of the Harley-Davidson XR750, which became the most successful racing motorcycle ever to turn a wheel on the dirt-track ovals of America. In addition to dirt track and road racing, O'Brien also directed diverse Harley-Davidson racing programs such as motocross, desert racing and land-speed record attempts. Of course he left HD for NASCAR and for eight years passed his proprietary methods to Ken Henderson of Henderson Performance. So like Emwold says, watch out for "Hanks Mule Rentals" or whatever he's talking about.
mdanehart
Oct 17, 2015 03:42 PM
ajohnston78
Jun 30, 2011 04:36 PM
2005 Roadking
Oct 9, 2010 11:18 AM
Coolhawg6622
May 8, 2010 09:12 AM
z edge
Exhaust System Topics
Oct 22, 2009 12:25 PM
