Abs??
Old Feb 13, 2017 | 01:14 PM
Vernal's Avatar
Vernal
Follow the brake lines:
http://partsfinder.onlinemicrofiche....INES%20-%20ABS
http://partsfinder.onlinemicrofiche....%20-%20NON-ABS
Old Feb 13, 2017 | 01:29 PM
multihdrdr's Avatar
multihdrdr
Of course people are unfamiliar with something right before they become familiar and that's underatandable, but...
When I hear something to the affect of "follow the brake lines", I think of this something like this...
Someone says "I'm trying to find out which side of the Toilet Tank the handle is on?"...
Someone else responds "Well, take off the tank lid and look for which side the lever is on"...
Whereas I say "Don't move now that your in front of toilet and look at it, now which side is the handle on?"
14Guineapig posted this previously which should be sufficient
Originally Posted by 14GuineaPig
It doesn't look like it. If you had ABS, you would see this
Here's another and you really don't need any bearing knowledge
How bout just looking at both side's bearing and spacer...
Do they look the same?...then NO ABS.
Do they look different?... then ABS
Old Feb 13, 2017 | 01:59 PM
Vernal's Avatar
Vernal
Did you bother to open the links and look at the parts diagrams for ABS and non ABS, or did you immediately go to the crapper?
Old Feb 13, 2017 | 02:42 PM
multihdrdr's Avatar
multihdrdr
I've been known to be guilty of going to the "crapper" quite a bit
If your serious about links and diagrams concerning wheels, spacers and bearing, I'm don't generally need to look at them because I deal them all the time. I tend to investigate interesting things (to me), that's why I've disassembled all the HD bearings specifically the OLD 3/4" and 1" x 21mm wide sealed bearings, ABS and the new 9276B bearing because they aren't traditional... "Inquiring minds (mine) want to know"
Old Feb 13, 2017 | 04:53 PM
Vernal's Avatar
Vernal
The post wasn't for you it was to help someone who is new to ABS.
Old Feb 13, 2017 | 04:56 PM
multihdrdr's Avatar
multihdrdr
So was mine...
Seeing a wire going down past the caliper directly to a different looking wheel spacer along with different looking bearing should be the first clue of something being different (having ABS, that's different) without having to trace a brake line...simple
Old Feb 14, 2017 | 06:58 AM
MilesOfTexas's Avatar
MilesOfTexas
IIRC, some year models had ABS available as an upgrade. It required the security and abs upgrade as a combination. Could it be an upgrade that could be performed at the dealer, and therefore the abs light that is not currently in use? OP, does your bike have security (in other words do you need a FOB to start the bike)?
1HDRIO
Harley Davidson Videos
Aug 7, 2014 08:28 AM
racehorse
Apr 24, 2014 05:25 PM
BALLS172
Apr 5, 2014 07:09 AM
JR-Boston
Wheels/Tires
May 10, 2010 01:51 PM
sgdiesel
May 24, 2009 03:31 AM
