Air Filter
Old Feb 15, 2017 | 05:54 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
A better flowing air filter doesn't do anything unless the engine can use that increase.
Using my 88 engine with a stock 5,800 rpm redline:
88 cubic inches is 0.051 cubic feet. It's a four stroke engine, so it only breathes half the time. 0.051 / 2 = 0.0255 cubic feet.
0.0255 x 5,800=148 cubic feet of air per minute.
That's assuming 100% engine efficiency, at redline.
So a filter breathing that will supply all the air the engine could possibly use. An air filter that supplies more does nothing, other than go longer in service before becoming a restriction from dirt buildup.
Do beware of over oiling the likes of a K&N filter. Many folk do, and that oil gets stripped off the fabric and deposited on things like sensors, which does not do them any good.
Old Feb 15, 2017 | 11:43 AM
OldPhat's Avatar
OldPhat
Foxtrapper-Most air filters will only feed the engine the air it can use, even a stock filter.
A stock air filter may feed all the air a Stage-I Harley engine can use, but still needs replacing.
I have used K&N filters for over 40 years. The first time it's cleaned & re-oiled, most of
the users learn not to over oil the filter element. On the plus side K&N's are your last air
filter you buy for that vehicle.
John
Old Feb 15, 2017 | 12:15 PM
harkon's Avatar
harkon
I have vent hoses putting hot oily air directly into my intake. So much so that occasionally I need to pull the cover and clean it up because it will drip. I cannot imagine an over oiled filter doing worse. That is unless it's physically dripping oil as you install it .... maybe then.
Old Feb 15, 2017 | 05:12 PM
rvkersh's Avatar
rvkersh
I have the big sucker open with the chrome outer cover,rain no problem, but very loud. You can here the air moving over the throttle plate, annoying.
prezflyr
Mar 1, 2014 11:11 PM
justmealwatts
Exhaust System Topics
Aug 9, 2010 12:24 PM
06STRD
Sep 5, 2008 07:14 PM
Springer95
Aug 18, 2008 07:27 AM
heritage3dale8
Dec 15, 2006 10:19 AM
