vibrations
Old Feb 15, 2017 | 09:32 PM
svarnster's Avatar
svarnster
Default vibrations
I changed the rubber bushings / cups on the rear swing arm pivot shaft and now I have bad vibrations thru floorboards and seat. almost un ride able. I used the drag specialties parts. this thing is vibrating worse than my ironhorse hard tail did
Old Feb 16, 2017 | 07:22 AM
GRWHD's Avatar
GRWHD
Did you check the front?
Sometimes replacing one causes the others to be more prominent.
Old Feb 16, 2017 | 08:28 AM
svarnster's Avatar
svarnster
I did front as well, I actually have the front bolt loose at this point trying to isolate the vibration
Old Feb 16, 2017 | 12:49 PM
wscott's Avatar
wscott
Were the aftermarket bushings you installed a harder / stiffer (poly?) material that that can transfer more vibration then stock oem did?
Or if not that i'd look for something to do with reinstalling the swingarm and tightened everything down there was some (new!) metal to metal contact to something associated with the motor thats now sending excessive vibration from motor to the floorboards that wasn't going on prior to installing the new rear swingarm bushings.
Scott
Old Feb 16, 2017 | 07:52 PM
svarnster's Avatar
svarnster
I think I am going to pull the swing arm back apart paying close attention to the bushings and their contact points.
Old Feb 21, 2017 | 08:34 PM
svarnster's Avatar
svarnster
It was the front motor mount from drag specialties, I put the original 1 back in and she rides good again.
nbowen805
Mar 16, 2018 06:24 AM
larsfum
EVO
May 19, 2014 07:49 PM
chuckw2
Jun 18, 2010 03:24 AM
Beemervet
EVO
11
Apr 2, 2008 08:26 AM
jhmp
Jan 2, 2008 08:32 PM
