Garaged - now what?
Old Feb 18, 2017 | 01:21 PM
Recon4's Avatar
Recon4
Default Garaged - now what?
Scoots can sit in a garage for extended periods of time in the winter months. How often do you crank up the twin-V if for no other reason to get some oil circulating throughout the engine? For how long? Any other must-do winter garage suggestions are appreciated.
Old Feb 18, 2017 | 01:24 PM
hdbob2006's Avatar
hdbob2006
Totally bad idea to 'start it once in a while'. That'll just caus econdensation inside the engine,and that is the last thing you want in there. start it only when you are ready to ride it for at least a half hour.
UppercaseJC's Avatar
UppercaseJC
I never start it until the end of storage. An engine that is not running doesn't need circulating oil. the internal parts will not lose the oil that is stuck to them.
Old Feb 18, 2017 | 01:44 PM
mkguitar's Avatar
mkguitar
Originally Posted by hdbob2006
Totally bad idea to 'start it once in a while'. That'll just cause condensation...
exactly this.
you are either in "using mode" or "storage mode", with washed and waxed surfaces, fuel tank empty or full and conditioned, cylinders oiled, fresh motor oil etc. you may even have the battery removed and inside on the bench, maybe lifted to take some weight off the tires
to revive, you can remove plugs, jack rear wheel and manually spin over motor to move oil around.
wait..... you are in Phx? this IS riding season- I don;t ride much in June~August unless headed out of State
mike
Old Feb 18, 2017 | 02:02 PM
Cygnusx51's Avatar
Cygnusx51
Instead of starting it up for no reason, you could take the down time to install a CB and learn to use GPS more effectively. Might as well use winter to your advantage!
Old Feb 18, 2017 | 02:03 PM
EricD10563's Avatar
EricD10563
I'm only starting the bike if I'm going to ride it and bring it up to operating temperature, otherwise like said above it stays in the garage on the battery tender.
Old Feb 18, 2017 | 03:26 PM
CRocks's Avatar
CRocks
When did they start having "winters" in Phoenix?
RollaMo's Avatar
RollaMo
Old Feb 18, 2017 | 04:11 PM
Recon4's Avatar
Recon4
Health issues. Hopefully back riding in May...
Old Feb 18, 2017 | 04:15 PM
Recon4's Avatar
Recon4
Health issues. Hope to back riding in May ...
