Trying to get lower...
Old Feb 21, 2017 | 08:42 PM
Domditizio's Avatar
Domditizio
Default Trying to get lower...
Hi all! I have a 05 flhpi... it's dropped 2" in the front and dirty air, air ride in the back. My question is, is there any way I am able to get the rear lower when aired all the way out? I know your all asking why I want to go any lower then I already am... but I do want to get lower. Am I able to drop a tire size in the rear or move the fender up or something? Any info would be helpful! I don't want to hear why I want it any lower...thanks in advance!
Old Feb 22, 2017 | 05:03 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
How creative (and expensive) do you want to go?
Fender clearance is the main issue. More specifically, the wiring there under the fender. Move the wiring and you can more safely let the tire scuff the fender at full suspension travel.
A smaller diameter wheel with a smaller diameter tire will let you drop the rear end lower to the ground. With a spoked wheel, you're only limited by your creativity in lacing a smaller rim on. Well, you're kinda limited by tire and rim strength, but I've no idea what the load capacities are for say 12-14" tires. Though if you use a car tire, the sky is your limit. There are still 13" tires out there that are strong enough, and perhaps even 10" trailer tires.
As for moving the fender up, you can. More easily with a solo seat, and especially with a cop solo seat. You can even get clever and hinge the fender at the front, and connect it to the lower shock mount so it rises and falls with the wheel. That would let you run it close to the tire at all times. You'll probably want to mount the rear lights onto some sort of frame mount, so they don't bob and flap with the fender motion.
The easiest way to get the lowest rear end with the stock fender for the lowest price would be to hard tail the rear with rods instead of shocks. You can make some crude ones with thick walled conduit just to see if you can handle the ride quality. Just hammer the ends, drill the holes and mount them. Paint them black and they'll blend in.
Just a few ideas on some ways to get your desired results.
Old Feb 22, 2017 | 09:08 AM
Domditizio's Avatar
Domditizio
Awesome thanks for all the help! I think I'll invest in a smaller wheel/tire setup..
lp77
Oct 11, 2016 01:19 PM
davidslay
Jul 7, 2010 10:41 PM
tj6969
Mar 23, 2009 10:15 PM
HarryDavidson
Oct 16, 2008 12:03 AM
renotunes
Ironhead
22
Oct 9, 2008 10:14 PM
