Fuelpak Numbers??
Old May 31, 2007 | 11:40 PM
Mikind7's Avatar
Mikind7
Default Fuelpak Numbers??
Has anyone ever figured out how Fuelpak maps work and what the numbers are all about? Seems to be a very simple system if tunable by the end user... Anybody?
Old Jun 1, 2007 | 09:56 AM
firespy999's Avatar
firespy999
Default RE: Fuelpak Numbers??
Don't know what the numbers mean but this may be of interest to someone. If your bike tends to stop or idle badly after fitting the fuelpak change setting #17 up one unit and that will cure it.
Old Jun 1, 2007 | 11:54 AM
gunrunner's Avatar
gunrunner
I had a fuel pak, not sure what each value is but seems its more than likly set up like all others with the +and- system, you could bump the number up to richen and lower it to lean.
Old Jun 1, 2007 | 12:03 PM
swomack's Avatar
swomack
Thats what bad about the FP. No one but V&H knows what the numbers are for and if you do an upgrade and it's not the same exact thing as something they've tested before you're screwed unless you live close enough to them to have them dyno the bike. I like my FP but if I knew then what I know now I would have never have bought it.
Old Jun 1, 2007 | 12:16 PM
spn98's Avatar
spn98
6th Gear
Call the tech number they are very helpful,I didnt have a clue and they walked me right thru it. GOOD LUCK
Old Jun 1, 2007 | 12:35 PM
mistermooster's Avatar
mistermooster
ORIGINAL: swomack
After I put one on my '06, I found I had lost a little power at the high end. I called V&H, the rep talked to the techs and gave me new numbers. Worked like a charm.
denalion22
Touring Parts
Mar 22, 2011 08:53 AM
Mikind7
Mar 29, 2008 07:08 PM
snooper0069
Dec 5, 2007 10:34 PM
harleyflo
Aug 8, 2007 10:13 PM
Mikind7
May 30, 2007 11:10 PM
