How to check heated grips
Old Mar 11, 2017 | 04:21 PM
Ashnic's Avatar
Ashnic
Default How to check heated grips
Real quick I installed new heated grips right after Christmas on my 17 RGS. Install simple enough after throwing away the directions. Well today I installed a set of 10" monkey bars..install went pretty good. Love the look and the feel of the bars. Everything went as planned other then my heated grips are dead? I didn't pinch any wires..really careful. Also I didn't pull the power wires thru..they are outside the bars. I checked all my fuses and everything looked good. How can I check and see if I have power at the left grip? Any help would be greatly appreciated..
Thanks..
Old Mar 11, 2017 | 04:42 PM
IKnowNot's Avatar
IKnowNot
Don't know if this will help, but there is a section at the end of the instructions under troubleshooting,
Hand Grips do not produce Heat
https://serviceinfo.harley-davidson....document/62330
Old Mar 11, 2017 | 05:47 PM
tpcowfish's Avatar
tpcowfish
Something i was told, and what fixed mine, the plug on end of bar, has prongs on it , that if not lined up will bend, check the prongs, might be it
Old Mar 11, 2017 | 07:04 PM
Ashnic's Avatar
Ashnic
Thanks my friend..first thing I did was go out and check continuity on the wires and soon as I looked bang there it was..one of the wires on the wire in the tube had pulled out of the plug..bang..hot grips again...Thanks again!
user 78082023840
2014-2024 Touring Models
May 23, 2018 10:43 PM
CR3999
20
Dec 29, 2016 08:55 PM
newrider66
Dec 21, 2016 12:07 PM
wparente
Dec 9, 2015 08:38 AM
INSteelersFan
Feb 5, 2013 11:45 AM
