12" yaffe monkey bars installation
Old Mar 13, 2017 | 08:40 PM
HOGNIT's Avatar
HOGNIT
Default 12" yaffe monkey bars installation
I will be installing a set of 12" monkey bars on a friends 2009 streetglide,what is all needed to do this ? As in extended cables, wires, etc
Old Mar 15, 2017 | 01:58 PM
Ash M.'s Avatar
Ash M.
Stage IV
So... i know there are some posts on here already. My 13 streetglide non abs with cruise is in pieces right now doing the same install. I ordered +6 clutch and brake and i ordered the namz wiring extension and tbw assembly from jp. I was never given an answer if it includes cruise control extension so i hope so. Also, i ordered clutch cover release gasket and clutch cable o-ring. You will need to drain trans fluid if you replace the clutch cable. Also order the snap ring kit for the control levers as mine were in bad shape. While it was apart, i went ahead and ordered arlen ness bushings to reduce vibration. Hope this helps.
Old Mar 16, 2017 | 07:29 AM
chase.hollowell's Avatar
chase.hollowell
I put the same bars on my 12 SG last year. Really you just need regular tools (wrenches, sockets) but you will also need torx, and hex bits( home depot sells a kit for $29.99) other than that, it really all just depends on you. I bought a kit that came with everything I needed( wire ext. cables, gasket, everything) Only thing I had to go buy again was the TBW from Harley, The damn green plug wouldn't pass the point on the bars. Best of luck, and take your time.
Old Mar 16, 2017 | 07:50 AM
Ash M.'s Avatar
Ash M.
Stage IV
Great.. im waiting on my 8 inch tbw extension. Did you buy the cvo tbw? I heard theyre longer.
Old Mar 16, 2017 | 08:03 AM
chase.hollowell
No I did not, They sell one extended, and one not extended. It was plenty long. I also had cut out the heated grip wires, as I live in Texas and figured I would never use them anyway.
Old Mar 16, 2017 | 08:33 AM
Ash M.'s Avatar
Ash M.
Stage IV
I'll keep you guys posted. Everything is apart and i already pulled the left side wires (no need to extend prior). Im dreading the right side.
Cozz
Dec 20, 2015 07:12 AM
kdawg187
General Topics/Tech Tips
Apr 11, 2014 10:26 PM
1liter
Apr 22, 2013 05:23 PM
thecort
Jan 4, 2011 04:19 PM
lkr0
Nov 21, 2010 08:31 AM
