The All things ROAD KING SPECIAL THREAD
Old Jan 8, 2020 | 05:18 PM
  #1991
Hush0088's Avatar
Hush0088
Stage III
Originally Posted by Doshounds
I got my windshield brackets back from powder coat and bolted up the Freedom Shields w/s. I am pretty happy with it. Couldn't ride tonight due to weather but I will get on it Sunday!
What size is the windshield you are running?
Old Jan 9, 2020 | 12:04 AM
  #1992
Doshounds's Avatar
Doshounds
If I remember correctly it is 16”.
Old Jan 15, 2020 | 12:52 PM
  #1993
SkullsAndChrome's Avatar
SkullsAndChrome
Originally Posted by GreenMonster
Added my windsplitter last night, first ride was on my way to work this morning . Still need to play with it but was getting buffeting and I’m 6ft. Still much better than no shield .
had to pull my handlebars back about an inch .
What headlight visor ring is that? Looks great. I read reviews that the HD Visor doesnt fit properly, and you actually mount it over the existing stock trim ring.
Old Jan 15, 2020 | 10:30 PM
  #1994
GreenMonster's Avatar
GreenMonster
it’s a HD visor , I had to pull the stock ring off but It still doesn’t seal the headlamp properly .
Old Jan 16, 2020 | 04:31 AM
  #1995
Mchad's Avatar
Mchad
I had the same trim, until I switched for the “frenched” version which mounts the same. Mine mounts fine, per the instructions. You just have to loosen the existing trim a bit.
Old Jan 16, 2020 | 07:42 AM
  #1996
SkullsAndChrome
Thanks. I don't understand why HD can't get it right. Did you leave the existing trim ring loose when you tightened the new one over it, or do you loosen to put the new one over it, then tighten again?
Old Jan 16, 2020 | 07:57 AM
  #1997
Mchad's Avatar
Mchad
Left it loose. Tightening the new trim tightens the original. It's rock solid. Not sure what the perceived issue is, as I installed three trims on two different road kings and never once had a problem. I honestly don't think its a HD issue, I think its a matter of people not following the installation instructions
Old Jan 16, 2020 | 10:03 AM
  #1998
SkullsAndChrome
Thanks. It's good to hear it from someone who actually did it, and followed the instructions.
Tom
Old Jan 16, 2020 | 10:13 AM
  #1999
Mchad's Avatar
Mchad
Tom
I see you are in NNJ - I'm just across the TZ. I have a set of black visor trims for headlights and aux lights. If you want them, you can come get them for the price of some beer and tequila...
Old Jan 16, 2020 | 10:19 AM
  #2000
mjwebb's Avatar
mjwebb
yup, easy peasy every time, same for auxiliary lamps
