Cam recommendations
Old Mar 25, 2017 | 10:49 PM
Daredevil's Avatar
Daredevil
1st Gear
Default Cam recommendations
Looking to do cam swap affordable . Not a 2 up rider off and on the rev limiter. Don't wanna spend a fortune. Any Andrew cams that might be a performance fit with a big sucker air cleaner gutted cat and slip ins with power commander 2012 road king classic
Old Mar 26, 2017 | 12:28 AM
Guntoter's Avatar
Guntoter
Andrews 57h. Designed just for what you want.
Old Mar 26, 2017 | 02:43 AM
bigpayback21's Avatar
bigpayback21
What he said
Old Mar 26, 2017 | 03:34 AM
bklynbob's Avatar
bklynbob
Set of SE 204 cams for sale in the multi fit classifieds. Page 10 or 11.
Old Mar 26, 2017 | 07:43 AM
Daredevil's Avatar
Daredevil
1st Gear
I was leaning that way . Just don't see the extra money to say I have woods ,lol in. My bike. Any other suggestions while I'm in there . Going out n through the top and using factory rods. Should I add or do anything to the clutch
Old Mar 26, 2017 | 08:57 AM
OldPhat's Avatar
OldPhat
A heavy duty clutch spring for the stock clutch can't hurt.
Old Mar 26, 2017 | 11:26 AM
Nightrain04's Avatar
Nightrain04
57h's is you live in the upper rpm's or 48h if you want torque down low.
Old Mar 26, 2017 | 11:49 AM
str8shuutr45's Avatar
str8shuutr45
I have a '13FLHR- did the 57 with Pro-pipe, Big Sucker, SERT, and Dyno tune- done in the fall of 2015. I rode it all last year but wasn't really happy with the tune. I decided to have it tuned again this off season. I just got the numbers - 97.68 HP and 107.2 TQ. Not bad for no head work.
Old Mar 26, 2017 | 03:29 PM
ericl's Avatar
ericl
I put the 48's in my 2010,
96" and it makes 95hp and 105 tq. Went with an AIM clutch lock
Old Mar 26, 2017 | 05:01 PM
jt metal's Avatar
jt metal
Lifters & brgs should be done as well.
Then if you get a good dyno tuner. You'll pick up a 10+h/p & torque that you'll leave on the table from the canned tune.
It's kinda funny. So $1500 bucks will pick you up 20&20
And a good dyno tune will net you an extra 10&10
I like cheap too......Just doesn't pay off all the time......Good luck
