Tour Pak lights going out....
Old Mar 28, 2017 | 06:20 PM
LunchBreak35's Avatar
LunchBreak35
Default Tour Pak lights going out....
So I have recently acquired a 1999 Ultra Classic with a quick disconnect tour pack... I hooked it up and when I pull the brake lever the running lights and brake lights go completely out. When I let off the brakes the lights slowly fade back in. Ive been told it could be a ground issue but where should I start looking for where the ground may be bad at? I see a ground wire not hooked up but its for the CB radio antennae but Im not using it so theres no cable ran to it at all. Any help would be appreciated.
Old Mar 28, 2017 | 07:48 PM
steelerdude1's Avatar
steelerdude1
I would start at the QD plug, make sure it's compleatly connected. Also look at the wires that get coiled up when removed. Something may have got pinched and is not making a good connection.
Old Mar 28, 2017 | 08:11 PM
LunchBreak35
Ill take a look... will probably have to pull all the heat shrink off of it and see what it looks like under neath
Old Mar 28, 2017 | 09:07 PM
Big Boz's Avatar
Big Boz
Take a look in the bottom of the tour pak and see if the grommet is still in place and look to see if the wires may have rubbed through on the edge of the support plate on the inside.
Old Mar 29, 2017 | 06:12 AM
grbrown's Avatar
grbrown
All the lights in your tourpak have two wires, the black providing the ground. Disconnect your tourpak and do some basic tests on it, by itself. You can do that with a pair of probes off the bike battery, but take care not to touch them together! Work around the pins in the qd on the tourpak and see if the lights come on properly or as you described. If they all come on crisp and bright the problem is in your bike harness, not the tourpak. If they are no better then work your way methodically through the tourpak wiring, where a multimeter will be useful, to identify where there is bad continuity.
Gunner E
2014-2024 Touring Models
Jul 1, 2019 06:39 PM
wharfcreek
Electrical/Lighting/Alarm
Oct 11, 2018 07:48 AM
KumaRide
Apr 25, 2016 04:42 AM
harley11
Apr 12, 2012 12:08 AM
2011BDSG103
Sep 4, 2011 03:27 PM
