New bars, where do the cables go???
Old Jun 3, 2007 | 06:27 PM
cubcake1's Avatar
cubcake1
Default New bars, where do the cables go???
I have put on new handle bars and now I am trying to put the grips and the turn signal/horn switches back on. The clutch and the switches dont fit together again, the wires are in the way, where do the wires go? Do I mash them between the two? I am not that good at describing, here are some pics.
Old Jun 3, 2007 | 06:31 PM
texas tom's Avatar
texas tom
Default RE: New bars, where do the cables go???
Those wires should be up against the bars not out like you have them,the bars have a dimple(depression if you will) that they go down into,what kind of bars did you put on? When you put the switches on hold the cable close to the bar before you assemble the two halves,if possible look at another bike they all go the same way..good luck..
Old Jun 3, 2007 | 06:37 PM
texas tom's Avatar
texas tom
Looking closer at your picture the wire bundle needs to be under the bottom switch half instead of between..look at bottom switch half put it on last over the wires with the wires running next to bottom of handlebar in the depression or dimple.
Old Jun 3, 2007 | 06:44 PM
cubcake1's Avatar
cubcake1
I put on herritage bars, they look identical (except for the shape obviously) to the stock ones I took off.
Old Jun 3, 2007 | 06:47 PM
texas tom's Avatar
texas tom
Do you understand what I was trying to tell you or did I confuse you more? If you cant figure it out pm me your number ill call you..
Bertk
2014-2024 Touring Models
206
Jun 9, 2020 05:14 PM
Mebeebo
Feb 19, 2012 09:56 AM
pointdogg48
Jan 22, 2012 10:32 AM
DR. V-TWIN
Oct 29, 2010 08:41 AM
DR. V-TWIN
May 30, 2010 12:45 AM
