99 road king swing arm issue
Old Apr 5, 2017 | 07:04 PM
rizzo's Avatar
rizzo
Originally Posted by hdbob2006
Replace the nut[both of them] with nylock nuts,then-Check axle alignment,check belt tension.A little bit of blue locktite wouldn't hurt.
Actually,Even if that nut fell off,it would be no problem,as long as the axle is tight.
What?
Old Apr 5, 2017 | 07:05 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
That nut is a locknut and should be tight on stud even when backed off. It should be replaced like you said if it's free spinning. However, nylock probably is not a substitue. OEM crimped locknut will last longer.
Old Apr 6, 2017 | 10:10 AM
grbrown's Avatar
grbrown
Exclamation
Originally Posted by hardcandydyna
Anyone ever have this before? I know 99-01 swingarms are junk but mine seems to not be cracked and in good shape, I seen this today though...
Is this of serious concern? Thanks for any help
Let's start again! Should you be concerned? Yes! Why? Because that device is the means by which your rear wheel is aligned in the swingarm and also your belt tension is set. The fact that it is loose, as we can see, suggests that your wheel is out of alignment and also that your belt tension is not correct. It also suggests that whoever last worked on that part of your bike didn't know what they were doing. There is an identical device on the other side of your swingarm, what condition is that in?
Old Apr 6, 2017 | 03:11 PM
Veekness's Avatar
Veekness
If you can't get the OEM part, and you aren't confident in a nylock nut, you can source a Stover locknut...available in the Dorman line, might be sourced thru McMaster Carr as well.
bernz
Jul 26, 2018 03:50 PM
47Norton
Dec 9, 2016 05:18 PM
South Jersey Scooter Trash
Touring Parts
Jun 22, 2015 02:50 PM
NoRegerts
Harley Davidson Videos
Dec 8, 2013 08:00 PM
Cyclone-G
Mar 2, 2013 10:45 AM
