tire change
Old Apr 5, 2017 | 11:31 AM
ozzy49938's Avatar
ozzy49938
Default tire change
Posted this in the tire section didn't find an answer. Maybe didn't explain it right. ( I'm known to do that) I'm changing my rear tire on my ultra. I got the wheel off and took the sprocket off. Under the sprocket is a form fitted rubber piece on the rim. I believe it is called a sprocket compensator isolator. May be wrong on the name. Anyway should I pull it out of the rim before bringing it to my INDY to change the tire for me.
Thanks
Old Apr 5, 2017 | 11:37 AM
Vernal's Avatar
Vernal
Yes take it out so it doesn't get lost. Wipe it down and check it for cracks.
Good Luck
http://partsfinder.onlinemicrofiche....A%20LIMITED%20[KE]%20WHEEL%20-%20REAR
dstiger
Jun 17, 2011 07:45 PM
kozy22
Mar 25, 2010 08:20 PM
skintbackfarms
Apr 26, 2009 08:44 AM
08UC
Mar 29, 2009 06:47 AM
Matrix
Mar 2, 2007 09:47 PM
