Correct me if I am wrong, but if you disconnected battery or computer, you are supposed to turn the ignition to on and then disconnect battery or computer. Otherwise, the security system that came with the bike is probably initiated. You will have to look up how to clear it.
Sooo, it was something simple. There is a small module under the seat over top of the battery that came loose. I'm told that it is the tilt angle sensor. Is this correct? In either case, clipped it back in where it goes, and sure enough the bike fired up. Hmmmf
Thanks to everyone for the help!
