TBW wiring issues
Old Apr 13, 2017 | 07:36 AM
DavidB99's Avatar
DavidB99
2nd Gear
Default TBW wiring issues
There are many, many posts here and in other forums of the problems people have with the little green TBW connector not seating properly, or jamming when being pulled through the right side of the bars, etc. Often the solution recommended is to simply cut and solder the wires to eliminate the connector completely.
But rather than solder what I did was to pull the wires (and their end connectors) out of their respective green housings. Then I simply plugged them together with a bit of shrink wrap around each wire to hold everything in place. Feeding it all through the bars went like a hot knife through butter - no fighting or tugging on wires required. And the best part is if I ever do need to replace anything all I have to do is cut the shrink wrap and pull it apart.
Seems a lot easier than soldering to me.
Old Apr 13, 2017 | 07:51 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Yep that's the way to do it. Thanks for sharing the tip. Welcome to the forums from Idaho and enjoy the ride.
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
TylerBoehm
Jun 11, 2014 02:14 AM
Dyna2007
Dec 27, 2009 07:34 PM
rubiconMike
Aug 29, 2008 07:44 PM
georgiabiker
Mar 19, 2008 06:57 PM
