An old cure for shifter shaft problems
Old Apr 21, 2017 | 10:43 AM
Veekness's Avatar
Veekness
I'll guess that HD omitted the Zerk fitting because the Real Bikers thought it was unsightly.
Old Apr 21, 2017 | 04:30 PM
paid4c4's Avatar
paid4c4
Thanks for posting the link to the pingel for those who aren't able or prepared to do mechanical work. I considered the Pingel but opted for the do it yourself approach for under 4 bux.
Bill
Old Apr 21, 2017 | 10:07 PM
penmaker's Avatar
penmaker
Originally Posted by btsom
Was told that years ago the factory put a grease fitting in that location. Guess they needed to save 60 cents on each bike.
My '99 Ultra had one
Old Apr 25, 2017 | 10:52 AM
hog-doc's Avatar
hog-doc
It wasnt the real bikers that thought it unsightly, but tbe modern "biker" that couldn't stand the sight of a little grease that might get on thier white sneakers or $100.00 "jeans"!
Old Apr 25, 2017 | 12:13 PM
Veekness's Avatar
Veekness
...and then there's that, of course!!!
Old Apr 25, 2017 | 07:13 PM
Inop's Avatar
Inop
$100 bucks holy crap......and how much for shipping? Good God pingle.
Old Apr 28, 2017 | 09:13 AM
Talldog's Avatar
Talldog
Originally Posted by paid4c4
While doing routine maintenance I decided to add a zerk fitting to the Shift Shaft. This allows for routine lubrication of the shaft which should limit wear and make for smoother shifts. I've already converted the OEM shift rod to one with Helms fittings. The zerk fitting is a self tapping fitting and requires the drilling of an 11/32 hole into the outside tunnel the shift shaft rides in. I use a marine grease which displaces water and should provide good lubrication for the shaft. The shaft showed signs of wear in only 4000 miles. The zerk fitting was sixty cents.
While doing this I decided to change out my shift rod. I used all thread rod from my local hardware story along with Helms fitting for the ends of the rod. Total cost about 8 dollars. I then covered the all thread with a piece of stainless tubing from the plumbing department for 2.50.
Bill
Thanks for the idea, was my rainy day project yesterday!
Old Apr 28, 2017 | 11:33 AM
cookie_62's Avatar
cookie_62
Did you use white lithium grease?
Old Apr 28, 2017 | 06:18 PM
dgoodbmw's Avatar
dgoodbmw
Default wrong drll size
Not trying to steal this post, but i went to look at drill bits and grease fitting threads and am pretty sure that an 11/32 bit is way too big. I am thinking a 7/32 would be closer. Anyone thinking about this better take a better look at what size hole he should drill. That could be a costly mistake.
Old Apr 28, 2017 | 08:24 PM
paid4c4's Avatar
paid4c4
Looks Great!
Bill
