PCV Question
Old Apr 19, 2017 | 07:51 PM
CGLTD's Avatar
CGLTD
Default PCV Question
Does the pcv come with the splices? Or was this something the previous owner did. Had the bike for a few years. Called dynojet, but they didn't seem to know what I.was talking about.
Old Apr 19, 2017 | 07:55 PM
bigskyroadglide's Avatar
bigskyroadglide
i never took the factory wiring sheath off, so i would not know
a picture to dynojet would be my suggestion
Does it work?
Old Apr 19, 2017 | 07:57 PM
rdc401's Avatar
rdc401
That's not with the pcv mine just plugged inline to ecm.
may have been some other tuner but I wouldn't know which one
Old Apr 19, 2017 | 08:06 PM
CGLTD's Avatar
CGLTD
It's curently drying. When rain water gets under the seat it doesn't work. I have dialectic grease around the plug not in pins. The sheaths were held together with electrical tape which were coming loose that's when I pulled it back. Found the wires, where the spices are, were wet. So wondering if water is getting in there? Even though the heat shrink seems good. This whole water thing started happening a year ago intermittantly. When it gets wet it either doesn't start or loses all power while driving. Unplug the pc and it's to go and plug it back in after it dries its also fine.
Old Apr 19, 2017 | 09:16 PM
bigskyroadglide
i had similar issue with pcv, not spliced wires but acting up in moist temps.. got stranded coming home from sturgis in rain. took it out of loop and ran the 800 miles home without it. did not worry about tune due to rain and cooler temps. this was on a 2010.
replaced with fp3.
no more problems.
Old Apr 19, 2017 | 09:28 PM
CGLTD's Avatar
CGLTD
I was thinking about the fp. I put 101k miles on my 05 Standard with the pc3 and never had an issue. I wonder why this is different?
Old Apr 19, 2017 | 09:33 PM
bigskyroadglide
i got 184k on my 04 with a pc3. still got it and ride it almost daily no issues
pcv acted funny from day 1.
i think its the ecm vs the pcv. something to do with O2 sensors and TBW in my opinion.
the fp3 has been flawless.. bad *** unit.
Old Apr 27, 2017 | 07:13 AM
CGLTD's Avatar
CGLTD
Called Fuel Moto with questions about fp3 and powervision. Spoke to Brian and he asked what was wrong with my PCV. He said it sounds like a ground issue and said to try and tweak the ground pin on the PC plug that connects to plug coming from the bike. He also stated that some of the plugs on the 08-13 touring bikes were not as good quality as other years and there is a very small percentage that they will have issues with piggy back tuners. I didn't buy the pc from them so I was very thankful that they they helped me trouble shoot even though I was ready to buy a flash tuner!
Needless to say I still had issues with the PCV and ordered a Power Vision with a FM map. Got it installed and seems to be running better than ever!
Old Apr 27, 2017 | 07:34 PM
madwrencher's Avatar
madwrencher
looks like the that lead is way shorter than it should be. Its good that you got a new pv and its working good.
DB249
Jun 8, 2012 12:53 PM
gja
Apr 26, 2010 07:18 PM
maddghost
May 20, 2009 08:46 PM
Scubadog
Mar 31, 2009 06:50 PM
Wrongturn
Mar 12, 2009 08:51 PM
