evo 1340 stater
Old Apr 22, 2017 | 03:27 AM
hawk61's Avatar
hawk61
Default evo 1340 stater
has anyone fitted a better stater higher than 32 amp as when at idle my bike drops lower than 10 until its near 1000 rpm then its at 12 or over i have standard gauge volt and a led volt fitted
Old Apr 22, 2017 | 11:01 AM
Big Dave's Avatar
Big Dave
I put a Cycle Electric 50 amp 3 phase stater , rotor and voltage regulator on my 98 roadking
Was an easy install and gave full output at an rpm
Dave
Old Apr 22, 2017 | 11:13 AM
Yamaharley's Avatar
Yamaharley
Sounds like your stock charging system is crapping out. A 32 amp stator should be giving you around 14v at 2000 rpm.
Old Apr 22, 2017 | 11:15 AM
Big Dave's Avatar
Big Dave
The kit i used was the CE-81A
Its a complete kit , even came with a new crank seal and breaker for battery connection all wires etc
Dave
Old Apr 22, 2017 | 11:51 AM
Yamaharley's Avatar
Yamaharley
You should go check out the evo section. A lot of great people that would really know the bike in question.
Old Apr 22, 2017 | 04:22 PM
grbrown's Avatar
grbrown
Wink
Check out the two Stickies in the Tech Electrical section, which give guidance on checking your charging system. There is another in the Evo section! Between them you should get a good idea if you have a charging problem.
BigGelvis
Jan 8, 2025 02:03 PM
cshocker
Audio Systems
18
Jul 22, 2019 03:40 PM
lmz5150
EVO
Mar 23, 2019 08:45 PM
Lunchboxx
Electrical/Lighting/Alarm
Jun 23, 2016 04:56 PM
cfd37buckeye
Aug 9, 2011 06:07 AM
