Headlight trim ring
Old Apr 12, 2008 | 09:02 PM
jcbpa's Avatar
jcbpa
Default RE: Headlight trim ring
Anyone know the part number for J and P?
Old Apr 13, 2008 | 11:58 AM
clarkchriston's Avatar
clarkchriston
Called J & P just yesterday about the 7" headlight trim ring for my 08 RKC part number (part# 3100431) and was told they no longer cary that product. They wouldn't give me any deails.
Old Apr 13, 2008 | 12:42 PM
YodaddyKeith's Avatar
YodaddyKeith
every supplier/reseller is now out of stock on the visored trim ring made by custom chrome......it was the only ring that fit properly....but that's ok because you can make the HD ring fit.
Remove the OEM ring and toss in trash, then bend underlying headlight mounting ring outwards in 4-5 places.....HD ring will now fit tightly and clamp fully with no gap......make sure to reinstall wire clip also.
Old Apr 13, 2008 | 01:47 PM
stillwater's Avatar
stillwater
Had the same problem on my '06 RKC last spring. Even following the directions by loosening off the original headlight ring - I never could get rid of the gap and ended up taking it off in disgust,then hanging it on the wall of my garage (to remind me to keep receipts). After reading these posts and the links within, I'll buy a replacement screw (the original'salmost completelystripped), and try again.
As far as retightening the original ring once the visor ring's in place -howdoes one get at the screw of the original through the visor trim ring?
Old Apr 13, 2008 | 04:38 PM
Shoe's Avatar
Shoe
ORIGINAL: clarkchriston
The trim ring was made by a company called Custom Chrome. They discontinued the trim ring for 2008 with no plans to re-intro/replace it.
I tried 6 different vendors looking for one, they don't exist anymore. I have since grown to like the gap......At least thats what I keep telling myself.
But seriously, I get alot of compliments on the trim rings and noone ever seems to bring up or care about the gap.
Dave
Old Apr 14, 2008 | 11:37 AM
clarkchriston
Here's the funny thing i learned over the weekend. My cousin just bought the headlight trim ring for his 06 heritage softtail classic and his trim ring completely replaces the old one. Installation was something like this: unscrew and remove OEM trim ring and discard, install new trim and secure with new screw. That's it folks. No jerking around with loosen this then fit that around there, then tighten this one first and secure that one second and you endup with a crappy gap (at least for most of us). I will be heading out on a ride wiht him this weekend and I am going to see if his trim ring will fit my bike. HD dealer said it won't work because my RKC uses a slightly different mounting assembly. His headlight measured 7" (Same as mine) and his trim ring is secured with a clip under the top of the trim ring and one screw at the bottom...just like mine. Worth a try and I'll let you know if it works
Old Apr 14, 2008 | 11:41 AM
clarkchriston
You wouldn't happen to have any photos would you. Where is the wire clip that needs to be installed.
Bobby12012
Oct 22, 2014 02:11 PM
billbuzz
Mar 11, 2014 08:53 PM
shagnasty
Feb 21, 2010 09:47 PM
rookiedan
Jul 10, 2009 09:21 AM
IAMSWUTIAMS
Softail Parts
Jun 1, 2009 08:48 PM
