Handlebar Riser Bolts
Old Apr 24, 2017 | 09:32 PM
Rickr01's Avatar
Rickr01
Default Handlebar Riser Bolts
Can I get to the handlebar riser bolts by just removing ignition and lower fairing switch cover to tighten them up a tad more? I put new handle bars on the bike and put it all back together then realized I should have snugged up the riser bolts while I was there. Thanks
Old Apr 24, 2017 | 09:47 PM
Rickr01's Avatar
Rickr01
Sorry its a 2010 Street Glide
Old Apr 25, 2017 | 12:13 PM
glcash's Avatar
glcash
Unscrew the radio and slide it back.
Old Apr 25, 2017 | 10:13 PM
hog-doc's Avatar
hog-doc
Riser bolts or top clamp bolts? Riser bolts, just need to turn bars to full lock each way and use an extension...top clamp bolts need to move radio!
Old Apr 26, 2017 | 07:49 AM
Rickr01's Avatar
Rickr01
Riser bolts...I pulled the Fairing etc. to put new handlebars on. After it was all done and back together with the exception of the inner fairing switch cap, I realized I should have snugged up the riser bolts. They are not really loose that I know of but after working on new bars, I notice I have a bit more fore and aft movement in riser bushings. I put stock bars back on, no apes. I had a stock set powdercoated to match the bikes paint. Thanks for the advice.
Old Apr 26, 2017 | 08:26 AM
hog-doc's Avatar
hog-doc
45 ft lbs on the riser bolts!
giangofett
Oct 28, 2017 06:54 AM
johnnyglass
Feb 22, 2016 01:20 PM
SgtMic
May 5, 2010 05:00 PM
dmax
Feb 9, 2010 03:55 PM
superglider
Sep 18, 2006 12:17 AM
