Compensator repair question
Old Apr 28, 2017 | 07:23 PM
danzio's Avatar
danzio
https://www.hdforums.com/forum/touri...l#post15950339
I repeat.
And I know it may not work for everybody. But it worked for me. And not everybody's tried it!
Old Apr 28, 2017 | 08:27 PM
big- mike's Avatar
big- mike
I just did a se compensator on my 2010 ultra last fall bought the kit from my local dealer I believe my cost was 289.00 plus gaskets
Old Apr 28, 2017 | 09:24 PM
voodoodrug's Avatar
voodoodrug
depends how long you want to keep it. tomorrow you could say thanks but i traded...only you really know?
my learning curve went like this.
over the years...got the se unit as an improvement,then the baker as an improvement. not really a grinding noise issue.
grinding noise came later but comp might have been related in the long run.
after a few band aids just dove in and replaced chain,clutch hud w/bearing,new starter 1.7kw and really stronger battery w/better cables. Already have mcr's,,,so about 700$ to address the hard starting grinding mess. like mensioned and in my hind sight it was various parts of the system.
Now when i hit the starter button theres a new thing that happens, the front of the bike seems to lift up and I hear the engine start.Its like all the power is focused on where it should be.
Old Apr 28, 2017 | 09:42 PM
wscott's Avatar
wscott
Originally Posted by boe1971200
I have been getting the occasional hard start and loud bang when I hit the starter on my 09 Road King Classic. Usually this happens when the bike is hot and has been running for a while. Yesterday I got home from a ride and stopped in the driveway to remove my helmet and open the shed door. When I went to start the bike it sounded like something was grinding pretty bad in the primary. I have been reading about it and it sounds like the compensator is shot. My question is for those who have had the repair done- what is the best case/worst case scenario as far as price is concerned? If I only have to replace the compensator its self it would be cheaper than if other parts are damaged right?
The reason I ask is I have been thinking of selling or trading the bike in. I wont stick the next guy with it but I do like to know how much of the money I have put aside for a newer bike will be spent to fix this one (if I do decide to trade/sell it).
I has same symptoms/issue on my 09 EG-ULTRA and replaced stock comp with a new HD SE comp kit approx 2.5-3yrs ago.
I have had no issues thus far with approx 16k+ miles on the new SE comp never hearing a clunk or bang on hot or clod startup again.
Cost me approx $370 for the new SE comp kit (inc new large rotor required for my 09) online from Surdyke and then add a few bucks more for outer prim case gasket,prim case oil and thats about it.
I chose to grind inner prim case (using Demel) to make enough clearance to install the larger new rotor that come with SE comp kit vs removing inner prim case.
I didnt need to replace the prim chain tensioner either because it had little to no wear showing on the rubbing block and didn't seen to have prim chain to tight either.
Unless i am overlooking something the complete job cost me approx $400.
Oh,forgot to also mention i didnt have to remove clutch basket assembly either because there was just enough stretch / slop in prim chain (w-prim chain adjuster removed) to remove old comp and then install new Se comp.
So between chhosing to not remove inner prim case and taking 10-15mins to grind outer prim case & not having to remove clutch basket assembly too that collectively saved me sig time and effort in doing the comp swap.
Scott
Old Apr 29, 2017 | 08:53 AM
mike5380's Avatar
mike5380
My compensator went out in the first 10,000 miles. My dealer replaced it with the SC compensator for about $500. No problems since then and about 48,000 miles on the bike.
Mike
Old May 16, 2017 | 06:20 AM
Bubba Zanetti's Avatar
Bubba Zanetti
So I had it to the dealer yesterday and scheduled to have the work done. While speaking to the service guy he mentioned that they would need to epoxy a part to the inside of the primary. WTF is that about?
Old May 16, 2017 | 06:42 AM
NELS's Avatar
NELS
Directs oil to the compensator.
Old May 16, 2017 | 06:48 AM
danzio's Avatar
danzio
Because the entire compensator design is so poor, there is no way to adequately get oil to flow upwards within the primary case to properly lubricate the compensator itself. The primary chain gets plenty of oil as it rotates it bathes in the oil in the bottom of the primary housing.
So the HD engineers basically came up with a workaround. They actually glue a plastic funnel to the upper portion of the inner primary so that as the chain runs through the pool of oil on the bottom it slings some of the oil upwards where it enters this "funnel" shaped plastic piece and that piece re-directs some of the primary case oil directly onto the compensator. Thought being that the added lubrication will add life to a poorly designed system.
Old May 16, 2017 | 06:55 AM
ColdRain's Avatar
ColdRain
I need to change bearings for the clutch. I think ill hit this issue at the same time. My starter sounds like it starts to turn the bike over then disengages to a grind. Does it more when hot but also once in a while on a cold start.
Old May 16, 2017 | 06:57 AM
Jackie Paper's Avatar
Jackie Paper
The battery is worn out or cables are loose more than likely. The banging is not the compensator. The compensator is a cast steel unfinished. It will make a little normal noise. If the compensator was so weak it banged on starts, it would bang like that ever gear shift and especially downshifts. Tin men started this BS and it will never die. Especially from people who fell for it and did it by shelling out big bucks.
Not saying some compensators have not broken and the contact areas were too soft and really made way too much noise. But that bang is not the comp.
