Compensator repair question
Old May 16, 2017 | 07:18 AM
Fxrc1's Avatar
Fxrc1
What's the best compensator? Barker or SE? I thank I need one for my 2008 Ultar Claissic.
But I want to get the best one for the long term.
Thanks!
Old May 16, 2017 | 07:23 AM
danzio's Avatar
danzio
Thanks!
Do a search in this very forum. You will find more information than you can digest in a week. You need to really research this issue before throwing money into a new comp. There are multiple threads discussing this and believe me, they will make your head spin.
Search some of my past threads for information on compensator failure, causes and at least in my case, the solution. Which was S&S Easy Start cams. I'm in no way saying this is a fix for all, but in my case it absolutely made the difference.
Old May 16, 2017 | 07:29 AM
lp's Avatar
lp
Originally Posted by RIPSAW
The battery is worn out or cables are loose more than likely. The banging is not the compensator. The compensator is a cast steel unfinished. It will make a little normal noise. If the compensator was so weak it banged on starts, it would bang like that ever gear shift and especially downshifts. Tin men started this BS and it will never die. Especially from people who fell for it and did it by shelling out big bucks.
Not saying some compensators have not broken and the contact areas were too soft and really made way too much noise. But that bang is not the comp.
There is a video somewhere showing exactly why it bangs on start up and only start up.
The difference is that your crank is not spinning at start up.
The weak springs allow the comp to turn to full lock, the chain bunches to one side, the crank starts to turn, then engine starts, the chain and comp goes full opposite direction and bangs against the other end stop like a rubber band.
Stuff is real. I've seen it and have experienced it. Furthermore, Mark at baker pointed this out, and someone went through the trouble of making a clear primary cover to watch it do it's thing.
They were not Tin Men - engineering types trying to help is what I saw.
Old May 16, 2017 | 07:50 AM
Jackie Paper's Avatar
Jackie Paper
Sure it will do what you say if the spring was that weak. Two things here, however, would also have to happen. Belville springs rarely wear out. They can fatigue and break but that is rare since the move very little and are in confines that do not permit that say in like you pull a coil spring too far.
It would do the same thing when you shift and apply a lot of throttle. The gas motor is way more powerful than that little starter motor. However, you can make a normal good compensator bang by WOT slam shift a Harley. However, if Harley designed it to take that, it would serve no purpose. It's purpose is to smooth that little uneven firing order impulses and the only two cylinder impulses. If a Harley was a V8, it would not even be needed. However, that rubber shock drive would be for sure.
Old May 16, 2017 | 08:13 AM
Bubba Zanetti's Avatar
Bubba Zanetti
The battery is in good shape, tested it about 2 weeks ago. As for the cables, I recently put a riders backrest on and dropped a nut down into the battery compartment. Had to pull the battery out to get it and I made sure the cables were good and tight when it went back in.
Old May 16, 2017 | 08:15 AM
Bubba Zanetti
Originally Posted by danzio
They actually glue a plastic funnel to the upper portion of the inner primary so that as the chain runs through the pool of oil on the bottom it slings some of the oil upwards where it enters this "funnel" shaped plastic piece
Has anyone had issue with this plastic piece falling off and getting ground to bits by the primary chain?
Old May 16, 2017 | 08:59 AM
lp's Avatar
lp
The difference is that "Starting" requires the comp to start spinning from a dead stop and the ramp will go to full end stop to get the crank spinning.
During that time the chain is pulling the ramp in the opposite direction it normally would be when the engine is running. Meaning, that the crank is being pulled by the chain (like on decel).
So the comp is being ramped in the opposite direction than when accelerating.
As soon as the engine starts/catches, the comp goes full on reverse direction as the crank out runs the compressed ramp.
The 07-2010? comp with it's weak springs will allow the ramp to bang/clap like a shotgun as it hits the opposite end stop.
When the engine and everything is already running/spinning, the springs are strong enough to keep the ramps centered and only deflect as much as the cylinder pulses.
When you down shift or gun it, the comp runs to one end stop and then slides back down to center after the load is removed or tapered.
It doesn't go from one end stop to end stop with considerable force - therefore no clap.
The newer comps employ a huge, much larger spring pack. Fixed the issue. No more clap.
I have never heard of it happening. May have, but have not seen it.
Old May 16, 2017 | 02:30 PM
Fxrc1's Avatar
Fxrc1
Yes I have read a lot in this and other forums. And my head is spinning! And compression release make sense to me actually been thinking that myself. Thanks for the reply
moosehunter22
Sep 4, 2015 11:50 PM
Sgt York
Jun 13, 2015 02:50 PM
devilock76
EVO
13
Feb 13, 2012 09:58 PM
Xarquath
EVO
Jul 29, 2010 10:44 PM
dsuppa
Sep 1, 2006 04:16 PM
