more low end
Old Apr 29, 2017 | 09:46 PM
HDSAE60's Avatar
HDSAE60
Default more low end
I have S&S 570 cams, 58mm TB, 5.3 injectors, ported heads on a 110" build. I would like more low end, should I use a +4 gear or change cams? I have some Woods 222 cams but haven't tried them in this build. What do you think?
Old Apr 29, 2017 | 09:59 PM
springers4ever's Avatar
springers4ever
Cool Compression ratio...
when you say a 110 build ...do you mean the 110 bolt on ??? do you know what the static and corrected compression is now ..???
the 4 degree wheel may help a little (you should know what the CCP is first)...but with the right tune (timing and AFR) at the throttle opening where you think you need more ...sometimes it's as ez as adding or subtracting a little here and there !!!
the 58mm may be a tad too big ....also ...
Old Apr 29, 2017 | 10:12 PM
HDSAE60's Avatar
HDSAE60
I have the race only tire shredder kit.
Old Apr 29, 2017 | 10:14 PM
HDSAE60's Avatar
HDSAE60
Also a power vision with target tune.
Old Apr 30, 2017 | 07:31 AM
GEORGEW's Avatar
GEORGEW
What Exhaust are you running?
Old Apr 30, 2017 | 08:42 AM
bklynbob's Avatar
bklynbob
Lower gearing......
Old Apr 30, 2017 | 11:00 AM
HDSAE60's Avatar
HDSAE60
Jackpot 2-1-2
Old Apr 30, 2017 | 11:51 AM
GEORGEW's Avatar
GEORGEW
[QUOTE=HDSAE60;16189150]Jackpot 2-1-2
Do you have a Dyno Sheet you can post?
Old Apr 30, 2017 | 12:58 PM
HDSAE60's Avatar
HDSAE60
No dyno sheet, or tuner any where around me.
Old Apr 30, 2017 | 01:16 PM
bklynbob's Avatar
bklynbob
Default Nice ride
GMR Performance is about 4 hours or so away.
