Eating rear wheel bearings
Old May 19, 2017 | 04:37 AM
simple softail's Avatar
simple softail
Default Eating rear wheel bearings
My son has an 02RK that he has owned for two years and has went through 2sets of rear wheel bearings already.
Now that he has it broke down I want to go over everything really good to find the cause and was wondering just what I needed to be looking for.
Any help would be greatly appreciated.
Old May 19, 2017 | 04:51 AM
NELS's Avatar
NELS
Never heard of this happening before.
Is he using quality bearings?
Wash his bike at the car wash and direct spray into bearings.
Maybe rides a lot in the rain.
Or possibly a different/custom wheel and not machined correctly?
Only things I can think of, but sure others will have ideas or cures.
Old May 19, 2017 | 05:48 AM
lt1-xjs's Avatar
lt1-xjs
Proper install is key. Those bearings should last a lifetime.
Old May 19, 2017 | 07:13 AM
larsfum's Avatar
larsfum
+1 Did he set the endplay up properly?
Old May 19, 2017 | 02:42 PM
multihdrdr's Avatar
multihdrdr
There is NO end play to set on 2000-later Sealed Ball. End Play was set on 1999-earlier Tapered Roller
But as mentioned, there is "proper" installation
Old May 19, 2017 | 03:47 PM
rkoivisto's Avatar
rkoivisto
Default Axle torque
Make sure you use the proper torque on the axle nut.
I believe some are experiencing bearing wear/failure is due to excessive pressure (overtight).
FISM
Jun 27, 2016 11:34 PM
Greenblood
Apr 16, 2016 06:36 PM
foxtrapper
Nov 17, 2014 09:11 AM
Masarov
Oct 5, 2012 07:55 PM
stlboarder
Jan 11, 2010 07:36 PM
